Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
09 Jetta subframe drop for arm removal?
I have a 09 Jetta Wagon with 2.5L regular 6 speed automatic. I need to replace my control arms but the clearance for the front bushings bolts is tight. Do I need to drop the subframe some to get them off?
Old 02-13-2017, 12:51 PM
Administrator
Dmitry at Pelican Parts's Avatar
Welcome to the forum! I've attached a DIY tech article from our site on replacing the control arms. If you have any further questions, feel free to post a Comment just below the article and someone will get back to you with more details. Best of luck!
Volkswagen Jetta Mk4 Front Control Arm Replacement | Jetta Mk4 2.0L (1998-2005) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 02-13-2017, 01:22 PM
-Dmitry
Dmitry thank you for replying. My Jetta is a MK5. The arms are different.
Old 02-13-2017, 02:36 PM
-Dmitry
Thanks for the reply. Although I have a MK5.......
Old 02-13-2017, 03:14 PM
Administrator
Luccia at Pelican Parts's Avatar
Yes, we do not have anything for the MKV. You should be able to drop the subframe slightly without removing it completely, but it might also give you more room to work if you remove it. However, it's not required.
Old 02-20-2017, 09:49 AM
