My new M3
I just bought a 99M3 with 58k. The only thing it needs os a new for light. One if them is cracked. Is this something that I can Fix myself? I know with some cars it is quite simple. if so what is the best procedure?
83 944na
Old 08-30-2006, 08:01 AM
supertack's Avatar
Headlight, taillight, side marker?
What are you trying to replace?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 08-30-2006, 11:02 AM
Sorry Fog light. I think a new fuse may do the trick.
83 944na
Old 08-30-2006, 01:03 PM
supertack's Avatar
Very possible. The fuse box is @ the top of the drivers side in the engine compartment. The inside of the cover should tell you what fuse is for the fogs.
If you need to replace the bulb, there is a retainer you need to release with a screw driver through the air duct in the front apron.
Begin by releasing the foglamp retaining catch. You push in on the catch. Once released, the foglamp is likely to just fall out and hit the ground.
Here is a foglight out of the car for you to see where you are pushing with the screwdriver.
97 328is
Old 08-31-2006, 04:22 AM
Thanks that is very helpful
83 944na
Old 08-31-2006, 01:42 PM
dboyles's Avatar
That is a gorgeous color combination. I'm not sure if you sought it out specifically, but if not, know that many people do. Take care of it!
Old 09-01-2006, 07:45 PM
