'89 944S2
M42 flywheel tooth count
Hi all,
I'm sorry if this has appeared in the wrong section. (Clicking on the E30 section brings me to the 101 projects section??) Can anyone help tell me number of teeth on the M42 flywheel (starter ring gear)? I bought a supposed M42 Aluminium flywheel, however, examination shows the clutch surface to be 240mm vice 215. Which is M3 or M52? The starter ring ring has 102 teeth. Internet search indicates that M52 gave 112/113. Ultimately it is a $100 gamble, but at the moment, I have no idea what I have bought. Many thanks in advance Greg |
Administrator
Posting in this section is just fine. Did you purchase the flywheel from us? If you're unsure what you bought, are you able to find a part number on it? With BMW is usually pretty hard to put the wrong part on the car, i.e. it not mounting up properly. The one below is for a '91 318is. It's the same one for all E30 '91'-92 318's, Z3 1.9L, and all E36 318's. (Counted 112, might want to count yourself).
