'feature' added to 930 starter
Hi All,
I recently purchased a 930 Turbo. It's a 1980's RoW 930, originally delivered in Switzerland. Early '90's it went to Texas and in 2010 it came back to Europe again. I've been renewing the complete suspension and while doing this, I noticed that the starter has a - non original - 'feature' added to it. Anyone knows what it could be for? The part itself is made in the USA and I suspect it was added during its stay in the States. What is it for?? ![]() ![]()
remote solenoid
to address either a bad solenoid on the starter or address a voltage drop issue (common on many VW air cooled) these where common on older fords |
It's a 914 ...
Also known as a relay. Not normally needed on a well maintained car, but it can give a better shot at giving full voltage to the starter solenoid when you turn the key. Also transfers the amperage load from the switching mechanism to the relay.
Ok thanks. Delete it and have the starter rebuild?
I would delete it and address anything wrong in the starter it self. For me, its just another possible failure point.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
As mentioned, Ford used these back in the day--you could remotely start the car with the key "on" while under the hood if you jammed a big screwdriver between those antenna-like terminals!
Could that solenoid be used in "reverse" to disable the starter based on a car alarm?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
you can put a hidden switch to control the added solenoid and that would cut the power from the battery to the starter. that would make it a true starter kill
1981 930 euro SOLD 1980 911 targa euro |
