AFR bung location
I want to install an AFR meter on my new engine. I am using one of Brian’s Zork tubes for my post turbo exhaust system. Where should I locate the bung for the sensor?
SR 86 930 x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette. |
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
As above, my understanding is anywhere after the turbo is best, so where Steve has it should be your guide...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Thanks! Looks like a good spot. We are going to have to remove the Zork to modify it so we will drill and weld then. With a bigger turbo unit (BW S200) the Zork comes out a little cockeyed and needs to be cut and rewelded.
Here’s where I put it, so far so good with the help of a heat break bung.
I also added a copper shield (heat sink) ![]() ![]() It’s tight with the bumper but it fits. I was burning countless sensor with an Innovate setup at stock location (pre-turbo), now with “colder” gas, heat break and PLX, it seems more durable.
Many projects on the way... 1987 930 Road trip car (1/2 owned) 1982 DP935 future beast 1969 911T rust bucket 1966 911 Buffum college car (1/2 owned) |
You can see it can be a tight fit - so you need to sort the angle out to clear the vehicle and try not to kink the wire too much. Ideally it should be in a near upright position - so water does not condense on the end of the sensor. Mine is on a zork - about 50mm after the turbo flange. You want to stay reasonably close to the turbo if possible - to get stable readings, ie as far off the open end of the tube as possible. So those factors pretty well determine where it is going.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Just to chime in on another option, though not necessarily the best. I put mine post-muffler, as far in from the end of the tail pipe as possible (about 10" in my case)....at the risk of erroneous lean readings at idle due to low exhaust volume and the possibility of ambient air sneaking in. Once past idle it seemed the gas volume was sufficient to preclude any exposure from ambient air and my readings were steady. Even if the readings weren't entirely accurate, at least it would err on the safe side reading leaner that actual if it was picking up any ambient air.
Again, not optimal location but it's what I did for what it's worth.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Above maybe 1,500 rpm or so this problem disappears.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Innovate still markets a tail pipe clamp affair for mounting their sensors. I wonder how much research went in to it?
"Patent-pending, Venturi-effect, tapped exhaust clamp for obtaining accurate lambda measurements in non-cat autos or other engines".
