Driver
Noah930's Avatar
overboost relay
I'm always thankful for this board. I had a no-start issue last week. I swapped the yellow overboost relay in the engine compartment for a spare, and the car started right up.
But now I want to replace the spare I had stashed in the frunk. Our host sells two versions: the Porsche-branded one and one made by Wittrin. Is there any difference? Is one any better than the other? I didn't want to get into a situation like the Bosch coils, where the German ones are good, but the Brazilian-made ones seem to be junk. Not something I want to find out on the side of the road.
1990 Black 964 C2 Targa
Old 02-01-2022, 09:48 AM
You likely already know this but if not, you can bypass the OB switch with a jumper wire.
I can’t recall the terminals for sure but I want to say 30 jumped to 86. Don’t quote me on that though. Also, it may be different on later years. Mine's a 81 so, no Lambda
Anyhow, for those who don’t know, that’s a hack that’ll keep our cars running in the event that the switch fails. Not sure on the quality of the aforementioned part.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-01-2022, 10:39 AM
Alan L's Avatar
The switch is just forming an earth contact which allows the fuel pump relays to run.
In o/boost it lifts the contact in the switch - breaking the earth circuit - relay shuts down, pumps stop. just earthing the wire on the switch will get things running. But you have no o/boost protection.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-01-2022, 10:54 AM
Driver
Noah930's Avatar
Yeah, I couldn’t recall which terminals to jump while stuck in a parking garage. Later a friend joked I shoulda just started jumping contacts randomly until stuff started sparking. The no-start thread stickies at the top of this forum says it should be 87 to 87a. Someone else thought it was 86 to 87a.
Old 02-01-2022, 08:20 PM
Alan L's Avatar
You don't need to touch the relay.
Pull the white wire on the o/boost sw, and earth it. Job done.
Alan
Old 02-01-2022, 11:03 PM
T77911S's Avatar
its 30 to 87a
the OB rly provides a path to ground via the OB switch for FP rlys to energize.
the OB rly works in the de-energized position. the air flow sensor energizes the OB rly to turn OFF the FPs when the engine is NOT running. this same ground path also goes through the speed rly under the seat for the rev limiter.
grounding the white wire wont do any good if the OB rly is either energized or the contacts (30-87a) are bad.
your contacts are probably dirty on the old one.
remove the cover and clean them with some 600 paper and see if that gives you a spare.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-02-2022, 04:36 AM
mark houghton's Avatar
go to post #5 for a picture of where to jump. I once got stranded and did not have a piece of wire but scrounged around on the road and round an aluminum pull tab from a beverage can....managed to straighten it out and insert as needed. A McGiver kind of thing. A guy can run all day long bypassing that relay but yes, you lose the overboost protection.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/887500-dead-h2o-2-save-your-ass.html
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-02-2022, 05:36 AM
T77911S's Avatar
you still have overboost protection with the OB ryl jumpered.
the over boost protection comes from the switch on the IC.
the OB ryl is there to turn off the FP if the engine is not running but key is on through the sensor plate switch
RACE CAR:: sold
Old 02-02-2022, 07:15 AM
Correct, my brain was mis-wired when I said what I said. What you don't get is the safety feature of the fuel pumps shutting down in the event of an accident where the engine has stalled but the ignition key is still in the on position...perhaps puking fuel all over the place.
Old 02-03-2022, 05:11 AM
T77911S's Avatar
I think it more possible to flood the engine or cylinder if you have it running too rich or a leaking injector.
RACE CAR:: sold
Old 02-04-2022, 04:43 AM
Jeff NJ's Avatar
I could swear I posted earlier, but it's not here?
Well, I wrote that I had an issue with my yellow relay and bought a new one, but pulled my original apart. I found a few broken solder connections on the board and easily resoldered them back together and it was good as new and in my parts box as a backup that I trust.
So give that a shot, you never know.
1988 930 Venetian Blue
Old 02-08-2022, 07:30 PM
T77911S's Avatar
yes, that's always good to do, same with the speed rely under the seat. solder joints are a common problem with electronics.
RACE CAR:: sold
Old 02-09-2022, 03:38 AM
