nreed's Avatar
915 Transmission lever shaft bushings
There is some play in my transmission lever shaft. I see on the Host's web page that the bushings are not available, or so it seems...
Transmission is a 915 in an '86 930. Item 19 is plastic(?) and items 18 are brass I assume.
1. How much shaft play is acceptable?
2. I can fabricate but need to know the bushing specs in terms of material and dimensions?
3. What are the part numbers?
4. Any advice or experience please.
Thanks,
Norm
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 03-15-2024, 06:59 PM
Alan L's Avatar
I am guessing but #18 may be propriety bush material - not brass. #19 may be similar. Judging from the pic I am thinking similar to strut bushes (internal).
If you get the dimensions you can probably source as such. I sourced my strut bushes that way - from a bush catalogue.
If you measure the shaft dimensions and the housing dimensions you will have your bush sizings.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-15-2024, 08:07 PM
