Breaking up at boost
I just got my car back from a year long body restoratuion, It breaks up a little under boost. It has new plugs,wires,distr cap . All new injectors and so on. Do you think the computer needs time to figure things ? I am putting on a fuel enrichment gauge to see what going on.
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
Sounds like your fuel mixture may be off - put a gauge on it and see what you get.
Are you running the stock US version CIS? AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Mine seems to crackle a little under boost as the weather gets cold. I think the abundant suply of cool, dense air might overwhelm the fuel supply if you have some mods with the stock fuel setup.
I am no expert ...just following a common sense hunch??? |
It seems to run better as it warms up so I think it is just blowing out cobwebs. I also found a loose front fuel pump relay cuts out a little this could be the problem.
o.k. just pulled over by state police, asking what the rush was told him I had boost issues he told if he catchs me again i will have legal issues. On the good side boost comes on nice now.
probably just a sticky CIS plate...happends if it sits still for a year. Mechanical stuff, you know
Thank you for your time, |
Re: Breaking up at boost
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
mine has a dme box under the seat
Thing under your seat might be a piece of lambda-regulating circuitry. I gues you have catalyst-equipped car?
