VERY Ingenious AFR Meter Install On A 930 - Pic!
Love this install - one of the best I have seen, A+++ for location, stealth but hate these gauges as they are not calibrated though....
Yasin
Old 04-21-2007, 05:18 AM
DRV2FST's Avatar
Most of us use a boost gauge in the clock position. Could you use the needle below the tach for an AFR? You would have to relable the area behind it from 10-15.
Kirk
Crashed: Silver 1992 Turbo S2
Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp)
Old 04-21-2007, 11:01 AM
Macht Schnell
les_garten's Avatar
Hi Dri2FST,
I have a similiar setup to yours. Could you send me the bin file from your Tec3r?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 04-22-2007, 08:23 AM
DRV2FST's Avatar
sure, email sent
Now does anyone have any idea if the boost needle can be used for AFR? I currently use an ugly digital meter. It is nice to have but I would prefer an analog readout. I can get the datalog from the Tec3r so I just want to use the needle for monitoring while driving.
Kirk
Old 04-22-2007, 08:49 AM
