KCPSG's Avatar
Signal line fitting ?
I need to relocate my signal line from the WG. I am thinking about getting a -6 AN bulkhead fitting and mount it right before the AFM on the elbow coming from the IC to the AFM. My question is....would the part of the fitting that would penetrate inside the pipe cause any strange air flow restrictions or any other problems for that matter?
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 05-11-2007, 06:12 AM
The signal line for the BOV has to be on the bottom side of the throttle plate(closest to the intake valve)
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-11-2007, 07:32 AM
KCPSG's Avatar
Roger that Ben...that is where its located. Same place Jerry showed in his pics of his install. I need to relocate my signal line for the WG. Right now it goes from WG to turbo outlet. I need to move it closer to the butterfly.
Phil
1998 BMW 328i
Old 05-11-2007, 08:24 AM
opps yeah then no problem
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-11-2007, 08:46 AM
