Smart quod bastardus
how to make stock wastegate adjustable
ANyone know how to make the stock wastegate adjustable for boost pressure.
I know that the central air tube from the wastegate housing goes to atmosphere. There should be a way of installing a pressure relief valve of some sort to this line to control the pressure to something below atmospheric. This would have the effect of creating a smaller differential pressure inside the wastegate and thus alowing more engine boost before it opens. I know the theary but need to know the hardware to make this work. Anyone have tried this that could show the install to do this? I was hoping to do this with mechanical valves or something inexpensive. Do not want to start springing big bucks for electronic boost controllers and such. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
sudo apt-get purge 930
What about a manual boost controller then? They are much less expensive than an EBC.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Fred its easy, Just put a knot in the line going to the bottom port, you didnt know?
Just kidding- I used to have a GFB (Go fast bits) mechanical boost controler and it worked great. I used a Tial 46 with a 12 lb spring. This controler used only the bottom port. I also have a Turbonetics manual in my garage that utalizes both the top and bottom ports. But the first one I mentioned was a lot simpler and worked great.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
My roller had one of those when I bought it.. Don't they call them "dial a grenades" for a reason ?
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Get a manual boost controller and leave the over boost switch connected. Mine has faultless for over a year.
It's easiest to leave the vent as it is and just reduce the pressure going to the bottom of the wastegate bell by ways of fitting controllable "vent" valve on a hose going to it.
It can be easy as simple plastic T-orifice or as complicated as electronically PWD-operated electro-magnetic valve. Just remember one thing: You cannot reduce the boost below basic spring setting, you can only raise it. That's why I'm a strong opponent to practice of fitting harder wastegate springs.
Thank you for your time, |
![]() If your talking about the turbonetics unit where you have to pull the knob up and turn to adjust; thats the exact same thing I was thinking. It felt like some kind of weapon of war that you set before tossing over enemy lines.
A fellow Pelacanite
You guys mean "Dial a Death"
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
or "Dial a Boom"
Oh by the way, I have one from the PO.. I'll be happy to sell it to you, make me an offer..
T
Interested.....this is exactly what I had in mind but did not know where to find one and who made them.
Can you send photos of what this looks like, both installed and not if you have them? Does it mount in the engine compartment then and you just set it and leave it alone? The factory 935 used a dial that was adjustable in the cockpit.....but this may be too tempting. thanks, Fred
It was mounted next to the emergency brake. I'll try to take a pic today and post it.
T
A fellow Pelacanite
I'm sure RUF did this as well and they were pressure regulators. They tee'd into the control line, the regulator went from the tee & then from the reg to the vent on the WG.
Here's a couple of pics,, Make me an offer , or guys let me know what it's worth I have no idea..
They're typically just a piece of billet or bar stock with a couple of pipe fittings, the total mechanism in the simpler types consisting of a ball bearing, a spring, an adjusting knob to tighten the spring and maybe a locking nut... No way I'd put one in the cockpit myself, with a CIS car.
'77 S with '78 930 power and a few other things. |
Thanks guys for the info.......how many of you have done this mod?
Any issues with it going out of adjustment......do not wanna hear about the blown engines from deliberatley dialing in 1.2bar boost.
Actually, that little red ring that you see under the adjustment ring goes down and locks the adjustment ring in place. You have to pull it up to make any adjustments, I can't imagine that it would ever come out of adjustment once it's been set, it's pretty rock solid.
Crotchety Old Bastard
I'm getting ready to experiment with a boost signal controller like the one pictured above.
What I plan to do is put an adjustable unit in the cockpit and a non-adjustable unit in the engine bay. The non-adjustable unit will be plumbed in parallel with the adjustable unit and will be locked down at a pre-tested 1.0bar. That way the adjustable unit can never exceed 1.0bar. The factory cutoff switch adds a double redundance of protection.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Can someone post a picture of the ones that Porsche supplied?
Pat
10 Ford Raptor 86 930 |
