930 Floating rotors
Hi
I have a 78 930 with floating rotors. Can I convert to normal non floating rotors, and still use the calipers and wheel setup? |
sudo apt-get purge 930
I think you have to use the later hubs to use non floating rotor/hats. I think it's 1980 and up.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Just curious, Why to change the floating rotors? Those are more than proven with the 917... where braking was of the essence.
Yes,
You can change, but not sure why. It would require a new rotor and a custom hat. Or like others have said, a factory later rotor and a later hub. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Floaters COST an arm & a leg.. to replace.
I have 2-piece fronts on my 87, just replaced the rotors at $395 per corner!
In addition to the cost, they are hell to find a source, PP has them as NLA.
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
Low Speed, High Drag
But they look sooooo nice!! Just got some new ones for mine.
EXACTLY. If you aren't tracking your car then why do you need floating rotors?
Shot of my rebuilt floaters...
Well, what about a after market rotor.
http://www.vehiclecraft.com/Brakes/vciweb4.htm Scroll down to the VCI 2000 floating. This might be where I go when I replace my rotors at the end of this season. Anybody have experience with these rotors? |
Thanks for the input.
I will keep my floating roters. |
Good decision!!!!!!!!!!!!!!
Certifiable
Where does one find the 2pc rotors for an 86-89 930? I'm about due!
What are the front and rear diameters?
Sean D. 1987 930 India Red/Beige/Black; Mahle 3.4L; Kokeln IC; K27 7200; GHL Headers; Borla Stainless Muffler; SC cams; Sachs Aluminum Clutch; Aluminum flywheel; Bilstein Sport Shocks; Adjustable Rear Sway Bar; Weltmeister Shock Tower Brace; Lowered and Corner Balanced; MOMO RSGT Seats... |
