3 restos WIP = psycho
Resonant knock frequency (kHz)= 900/(pi x cylinder radius) http://www.phormula.co.uk/KnockCalculator.aspx
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
subscribed...
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Super Moderator
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Project 935 Blackbird with knock controller. Claims 900 hp at 1.6bar
I'm pretty sure the engine was done by Turbo Mike in SoCal. He installs the knock controller between a F.A.S.T. EMS and two MSD7's. Reader's Digest condensed version: http://www.6speedonline.com/forums/930-turbo/179696-reapers-blackbird-build-chronicle.html Long thread: http://forums.pelicanparts.com/showthread.php?t=364751 |
If you are only going to run 1 sensor, why not place it somewhere on the case?
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Did I mention we have a 30 day money back trial?
I will waive the normal 10% restocking fee to the first one that orders. |
Where are people placing them otherwise? I read about the crankcase breather but I'm not sure where that is located. Anyone have a pic of that area? |
For starters, yes, you need two, once on each cylinder bank, just like the 993s do.
Second, these will fit any 911/930, as long as you drill and tap the underside of the cooling fins so you can bolt these solidly to the cylinders.
As an aside, can a single J&S unit run 6 coils on a twin-plug wasted-spark motor controlled by MS-II and parallel EDIS units? I already have a Bosch sensor on the case oil breather cover running a KnockSense module that has already given up the ghost.
Please post or mail me a wiring diagram.
See the two links at the top of my home page for waste spark or coil on plug applications. One of these should be able to do the job. |
To retain dual plug waste spark, you would need two three channel Vampires.
We have a single box version for dual plug with twin distributors. |
Wer bremst verliert
That's my diagram above, I dont use MS anymore, but similar setup through my Adaptronic ECU. I use two triple-channel Haltech ignitors. When they work they're great but I've had some QC issues.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
JohnJL:
The Adaptronic has three outputs that go to two three channel igniters? The Interceptor version will work. Three inputs from the Adaptronic, three outputs to each igniter. |
forwheeler:
You have the same set up as sjf911? According to the drawing posted, you would need two three channel Vampires. |
