I wonder how much each of those ion sensing pencil coils will cost?
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Super Moderator
gorean et al.;
all that sounds good for when it's available in the future and i hope it's available soon. while we're waiting for a better mousetrap, the vipec, wolf, and j&s safeguards all work extremely well. proven on the dyno and on the track. plug-and-play. on porsches. today.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) Last edited by nize; 11-01-2009 at 08:35 AM.. |
Super Moderator
now that i think of it, given how active j&s john is in the industry, i would not be surprised if he came out with a new j&s system that uses ion sensors. in the end, it's enthusiasts like us who win.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
3 restos WIP = psycho
Ah, technology. The R&D depts are already experimenting with integrated ignition/DFI/ion sensing cartridges that will fit the center plug hole location of most engines. I am just waiting for the day that I can drop two of these into my early 911s twin plug holes.
![]() Since we are still living in today, looks like Wolf and J&S are my solution.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Smokey - 1986 951 2.7 liter MID sleeve big bore with Vitesse and CEP parts, Link G4 Extreme, lots more. "The first 50% of the project takes 90% of the time... The rest of the project takes the other 90% of the time." |
Bob Boyer at Random EMS gave me the skinny yesterday - he has a great wealth of knowledge to share. It doesn't hurt that he lives 3 miles down the road.
Super Moderator
he also has one of the fastest race-dominating 951's in the world, running wolf EMS with J&S safeguard;
the wolf+j&s has also been running on several race-winning 930's for several years.
Manassas, VA
I wonder what kind of downforce he is getting from that rear wing? It sure looks like a steep angle of attack!
Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
J&S Ion Sensing
Yes, I have been working on an Ion Sensing system, starting in 2011. I made a couple false starts, then began again in 2015.
It's been on and off the back burner, since my wife died from cancer, then again after I was hit by a car while walking, broke both my legs, two years ago. I'm doing well now, but my right knee is messed up. It will take knee replacement surgery to fix it, but I can walk and play pool as is. The initial version is for distributor ignition. I have a pre-production version installed on a 1990 Chevy Suburban. The ion sensing electronics are mounted and encapsulated on top of the distributor cap, with connectors feeding the ion signals to the processor unit, and supplying power to the ion sensors. I have another version in the works for direct ignition, but I'm not ready to publish anything on it. This version requires an MSD or other CDI system. I designed the processor unit in 2016, but I don't know what the final version will look like. It has a small oscilloscope mounted on the front panel, so you can monitor the ion signals, but that scope went out of production as I was finishing the first prototype. The designer sold me the parts to build and install another one in the second unit. The processor has a bunch of knobs, switches, and LED's, and is designed as a research tool, not really for the retail customer, as I don't know what features will end up in the production version. It has output jacks to feed signals to an external lab scope, with a knob to select what signals are being looked at, and one to select which cylinder is being displayed. It also has an input for an acoustic knock sensor, using the same detection and control system as used in my SafeGuard system. One of the switches on the front panel let you select knock control by ion sensor or by knock sensor. The acoustic sensor will probably go away in the production version. I included it in the prototype as a way to "prove" the ion system is actually detecting knock signals. An LED array shows misfire with yellow LED's, knock with orange LED's, and, preignition with red LED's, for each cylinder, and there is the familiar LED bargraph I use in my SafeGuard gauge, showing the amount of retard from either the ion sensors or the acoustic knock sensor. I also included an off the shelf eight channel data collection system with USB output. The user interface is straight out of the '80's, and needs to be updated, but I ran out of knowledge. ![]() ![]() ![]() ![]() ![]() |
Banned
930 engine makes too much noise as well to use a knock sensor.
No, the 930 engine is not too noisy to use with knock sensors. Where did you get that idea?
Several members on here are using the SafeGuard system. Do a search on here to see who is using it, then ask them if it works. |
