Blitzkrieg
jly535's Avatar
Pulling diff out????
I think my diff just went tits up, so I am pulling out this weekend. I got CV axle off and all bolts on diff side cover off. Do I need to remove big nut on center of CV axle flange on diff? Any other pointers or advice? I believe I have the Quaife ATB, will know shortly. Thanx, Jamie
Old 10-11-2008, 01:11 PM
A930Rocket's Avatar
I've not taken mine apart, but there's more to it than taking the side cover off. That may give you some access, but I don't think it will really allow you to work on it.
Be careful.
Old 10-11-2008, 01:19 PM
Blitzkrieg
jly535's Avatar
Be careful.
I am sure I can pull the diff out without removing trans, then work on diff on bench or send out for rebuild. Thanx for input, Jamie
Old 10-11-2008, 01:33 PM
rsrmike's Avatar
take both axles loose, remove both drive flanges, pop diff cover off and diff will fall in your face
Yes, be careful, it's heavy and awkward
Professional Overcomplicator
Old 10-11-2008, 03:11 PM
Blitzkrieg
jly535's Avatar
Thats what I needed, Thanx, Jamie
Old 10-11-2008, 04:58 PM
