935TURBO's Avatar
BBS Rims........Got a problem......?
I had a big problem with one of my wheels......a rim is broken......and I was only runing on good roads....not racing........
Does anyone of you had the problem......?......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 10-19-2008, 11:17 AM
You can just change the barrel... there is a online web site that specializes in 2 and 3 piece racing wheels but I can remember the address right now.
Are these aluminum or magnesium ? I had some aluminum 3 piece BBS rims and they also had cracking. I guess there pretty fragile. How old is this set?
Old 10-19-2008, 11:22 AM
935TURBO's Avatar
They are magnesium rims.....they were quite new....11" x 17"......
Old 10-19-2008, 11:36 AM
A930Rocket's Avatar
Not to question you, but the wheel center looks cast aluminum and to be honest, so does the wheel half from the way it fractured I've had both cracked magnesium wheel centers and halves that have never looked like that. I've had magnesium wheels dated from the mid 90s to 2003 that didn't look like those and I know the newer ones don't.
Where did you get them from and are you sure they are BBS? I'm on an iPhone and it's hard to see the name.
Old 10-19-2008, 12:10 PM
935TURBO's Avatar
No comments......that's the reason of this thread......
Old 10-19-2008, 01:00 PM
7.0:1 > 11.3:1 > 7.0:1
I've had cracks form at the bead lip which progressed inwards. These are not high life cycle parts and were never intended for street use.
Old 10-19-2008, 01:20 PM
935TURBO's Avatar
So Jim.....shall I got alu insides...?....if that's avalable....?....
Old 10-19-2008, 01:31 PM
? yes the halves are aluminum. The honeycomb center (gold part) is cast magnesium.
They must have a distributer in Europe http://www.bbs-racing-wheels.com/Seiten/frameE.htm
Old 10-19-2008, 01:39 PM
935TURBO's Avatar
Yes, thanks Jim....I know them....and the girl at the sales department is really helpfull.....but I was wondering if that was normal.....and if that kind of problem often happen....?
Old 10-19-2008, 01:46 PM
WPOZZZ's Avatar
Serge - Sorry to see that happen to you. Did you paint the inners because I have never seen that finish before. As said before, you can just order new halves, but this time, get the heavy duty TI50 inners.
Old 10-19-2008, 04:55 PM
A930Rocket's Avatar
Who ever built them did not use the proper aluminum ring and gasket between the two halves it looks like.
Of course, I've been wrong before.
Old 10-19-2008, 05:31 PM
A930Rocket's Avatar
Are all the halves stamped with BBS on them in addition to the stickers? Lots of wheel halves are interchangeable.
Old 10-19-2008, 05:32 PM
WPOZZZ's Avatar
It looks like you are correct as the aluminum ring would have left a little more gap between the halves.
Old 10-19-2008, 09:13 PM
935TURBO's Avatar
I'll check all that and let you know ....the wheels will be taken off the car today....
The painting is a very very thin coat, done by a professionnal (FIXALU, specialised for rim works)....and I did it for protecting the inside of the rim against the brake dust....
Old 10-20-2008, 12:32 AM
WPOZZZ's Avatar
Just be glad that you found the crack and it didn't find you at high speeds.
Old 10-20-2008, 12:36 AM
935TURBO's Avatar
I've been very lucky on that deal..........I found it, only because my tire was flat and noway to blow it up again......
Old 10-20-2008, 12:41 AM
Blackbird Pilot
Reaper930's Avatar
Wow, sorry to hear Serge. Glad you noticed it! Now i know to watch out for this....
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 10-20-2008, 03:21 AM
935TURBO's Avatar
Hi Reaper....congratulations....your 935 is on the right way.....
Yes....be carrefull with that....and I think that crazy power with such large tyres is not helpfull.......
Old 10-20-2008, 10:01 AM
Me like track days
Craig 930 RS's Avatar
Man, I just do not like the engineered design of that wheel.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-20-2008, 10:23 AM
935TURBO's Avatar
Hi craig....what do you mean...?
Old 10-20-2008, 10:29 AM
