boost question
Hey guys just a couple of questions regarding boost. I have had my 930T for a couple of months now and still loving it. I have noticed that boost starts to come on at about 3500 rpm and then takes a long time to get to 1 bar. To me it feels like a lifetime. Is this normal, and is there something that I should check out?
In the very near future I will be upgrading to new headers and exhaust to hopefully help with this delay. Is there anything else that I can do? Current set up is a garrett turbo not sure which one, cannot find anything on the turbo to help me ID it. Also sc cams. I have been watching youtube vids of other 930 turbos and they seem to build boost much faster and seem much more responsive. Probably should let another 930 owner drive my car. I have not ever been in another 930T so it is hard to compare. Thanks, Steve
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
Twins are more fun!
Check that you don't have any vacuum leaks etc. That'd be the first place I'd check.
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
Registered Driver
What headers/exhaust do you have on there now? Sounds like it has had a little bit of work done to it so maybe just a leak somewhere or maybe a turbo issue.
It would be handy to know what turbo you have and if there is any smoke/oil issues you have noticed. And as always photos plz...
Ben '85 930 - Black on Black '95 993 Turbo - Silver |
I have stock headers and exhaust right now. However their is no catalytic converter. I do smoke for just a few seconds occasionally at start up. But my 996TT does this as well so I figured it was normal. I also noticed that the O2 sensor is not connected, and I have left it that way. The car seems to run very good, and boosts to 1bar and holds to redline, just kinda slow to get there. Maybe I am just used to the violence of the 996. Also I was watching some vids of 930T on youtube and it just seemed that they built boost much faster. This could be my imagination.
Maybe it is that I am not used to the long gears. When I turn a corner in 2nd and gun it, it seems to take forever build boost. I often hear people give advice to the new owners to make sure you are pointing straight before hammering it. I have yet to feel the danger. I have noticed that if I am cruising at 4K rpm, than yes it comes on fairly quickly but 2.5-3.5K, she takes her sweet time. I will ID the turbo soon.
Crotchety Old Bastard
2500-3500rpm with slow response is the characteristic of an old 3LDZ or 7006 turbo. Hammer the throttle and count to 5 then hold on! Even my old 7200 11.11 has that charcteristic to 2800rpm.
This is not to say that you may have a leak somewhere or heat soak, etc as well.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
"I have stock headers and exhaust right now."
"Current set up is a garret turbo however I don't know which one." Steve, I think you explained a lot of it right there. A set of B+B headers will give you 35 horsepower and much better throttle response. Also a member here is working on a set of 993 headers to fit right onto a 930, and that will be dyno tested soon. That is a new hybrid product which could have a lot better quality and price than B+B, although horsepower gains are still to be determined. Rarlyl8 has several light weight mufflers and straight pipes. And who knows what size turbine you are pushing, it could be a huge mismatch. |
beancounter
Banned
sounds like a fun ride - I'm picturing it now... sigh. I was thinking the same thing on being in 1st Jacob. Steve, depends on how slow a 2nd gear corner you're taking. It could be 1st is more friendly in those situations. Prob then is it takes your double clutch deftness to defy 1st gear synchro idiosyncrisity, uh huh. Before wondering about car issues, I was going to ask 'in what gear do you mean?' Boost onset varies gear to gear and by scenario. So the lag'd onset in 1st - sure - as late as 4000-4200. 2nd-4th, more in the 3500 range but sometimes 3800 if mess up the situation enough. 'Tis def. a whole nuther animal from that of your twin k24'd TT. And that's a good thing 8-). The point it straight and hold on is there, you'll start finding more of it as your settle your technique in with it as the miles pass. Sure is fun. Forevergears are adddddddictivvvvvvvve (hence my profile 'location')... Def. give it a twice over tho to ensure nothing awry in thar... |
I took my car for a cool morning drive. I kept it above 4K and the car felt and handled like a race car. If I accidently let the RPM's drop below 3K, back to hurry up and wait for boost. As far as taking a surface street corner in first, well it is impossible for me to shift my car into first unless I am at a complete stop. Not sure if you guys experience this as well. Sometimes I have to come to a complete stop, then shift into 2nd, then first is much easier.
After my header and exhaust installation, I will see how the car feels. I will also dyno and post the results to make sure everything is OK. I truly value the opinions on this forum. The knowledge in incredible. Thanks!
Here is a list of everything else you need to check anyway when you get a 930: Clutch adjustment to make sure it goes into every gear correctly. Are the shifting bushings all in new condition... there is a ball bushing at the bottom of your shifter and two other bushings, all in the shift tunnel. Finally your engine and tranny mounts must be in acceptable condition. Swapping in wevo semi solids is the way to go, IMO. But that increases noise if you do it to the tranny mounts. Not saying you need all or any of the above but that covers the bases. |
Ahhh the old 3-2-1 shift. I will try that. I have just recently switched out all the bushing using the directions in 101 projects. Maybe I will work on clutch adjustment next. Not sure if I want to tackle that myself or not. I actually enjoy all of the idiosyncrasies of the car, yes she is old but is also imo the best car ever made. I enjoy taking care of the car and fixing what needs to be fixed.
beancounter
Steve,
I've had my car for over a year now (and about 5,000 miles of smiles). I feel like I am only just getting comfortable with the downshift into 1st. I had the tranny rebuilt, and even with brand new dogs and sliders, the 2nd into 1st downshift is not easy. I have read that a newly rebuilt box needs time to "break in," so it might be that its getting easier as the new parts wear-in. More likely, its that I am getting more comfortable in the car and honing my technique: preferably double clutch and mash the throttle to get the revs up and she slides into 1st while underway without much effort. I took her for a spanking around my neighborhood one day last fall after I finally fixed an annoying acceleration stumble, so I was really pumped. Without thinking, I nailed the 2nd to 1st downshift rounding a 90 degree urban corner and got into the gas (boost came right on) and the ass-end kicked out on me about 12 inches or so...didn't mean to do it, honestly officer
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Banned
While each gearbox will differ from the next in terms of action / condition / willingness, my above statement is spot on. You need to hone your technique and be on your game. The prob with 'chucking revs' @ a 930 to invoke said downshift is... friggin lack of throttle response. Jacob made good reference to it with "mash the throttle". But again, depends on the condition of your box and the alignment of the linkages, etc. Dancing those pedals tho - man - truly what makes these cars so fun. ps. Jacob, your story had me chuckling - good stuff |
boost question
if you are not toe and heal will be difficult to get 1 in lower reps and in my opinion you can not drive to the full potential without
