need help!! car acting up! asap!!!
hey i need a little advice if you guys can lend it, i was out tonight and i'm pulling into my fiance's neighborhood, and the tach starts going nuts bounces up and down goes all the way over and then dies out completely, and then when i get in the driveway i cut it off.. and it won't start for about 5 min... then all of a sudden it starts but the tach is still dead, and then i cut if off and try again and it does the same thing...
i can't really think of anything else tat was screwing up other than the boost characteristics were a little different than i had noticed before, it was surging more than normal at 4k and above, and partial throttle up high it would suddenly feel like i let off the throttle and slow down real bad but i was still in it a little, but under wot it pulled as hard as it ever does?? i'm so confused!!! |
MEMBER # 930
Vacume leak , hose popped off ? Gist a thought !
MEMBER # 930 |
Check the voltage regulator.
Make sure you are getting proper voltage from the alternator. |
Crotchety Old Bastard
Ditto on the alternator. Check all your connections and output.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Electrical is my vote, as in a bad ground or loose wire at the distributor or coil. The symptoms of the tach doing the mumbo-jumbo are tell-tale signs of bad connections. Your other running symptoms also reek of poor or intermittent spark.
I don't know that I can point you where to look first, but I bet a dozen other guys lurking around here can, so stay tuned!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Same thing happened to me...turned out to be the alternator....then the battery because it wasn't being charged properly by the alternator...start with the alternator....but you might also check the charge levgel on your battery. Do you have a voltmeter? it should read at least 12.5....preferably 12.7
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 02-20-2009 at 12:25 PM.. |
Alternator
___________________ Ryan 2001 996 Twin Turbo 1982 930 |
+1 on the alternator,, I suggest you charge your battery,, then hook it back up.. Start the engine and look at the voltage, running it shoudl be around 13.8 volts.. if the alternator is going bad will be significantly higher
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Wayah Road Warrior
I suspect the flames from your boost over-run melted your ..... wait for it ..... alternator!
http://www.youtube.com/watch?v=cZSN_6Alhis But seriously ... its your alternator.
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) |
hahaha ... very funny!!
Well thanks everyone for the quick replies.. i got it back down to the shop, and waiting to find out if its the alternator or regulator... hopefully the battery is still good!! but thanks again everyone!! |
