Rattling noise
Hi,
My stock '87 developed some rattling noise, it seems to be coming from the blow off valve, so I replaced the two gaskets but the noise still exists.
This is what happens, after the car warms up and I drive about 25 miles or so the noise will start when I throttle and continues when I ease off the throttle.Otherwise, it drives fine and the boost is fine.
I need some help to see what else to check to eliminate that noise.
Thanks,
Yahow
Old 05-02-2009, 10:49 AM
Forced Induction Junkie
WERK I's Avatar
I would go to an auto parts store and buy one of those cheap stethoscopes and try to isolate the sound in that manner. First place I would listen, the valve covers. It could be coming from so many places, hopefully nothing that is a lot of $$$$$$.
Sometimes the fan belts harden in funny ways and you may have a bad belt. Buy belt dressing and spray the belt with the engine running and see if the noise disappears.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-03-2009, 05:58 AM
Hi Dave,
Thanks for your pointers, I will get it a try.
Yahow
Old 05-03-2009, 06:24 AM
A fellow Pelacanite
NathanUK's Avatar
Could be one of the idler wheels on the chain tensioners. Use a stethoscope as suggested.
You may have one of the holes partially clogged in one of the cam spray bars. A stretched chain is another possibility. A rocker could be loose.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-03-2009, 01:38 PM
NathanUK,
I will check them out too.
Thanks, Yahow
Old 05-04-2009, 05:47 AM
Rattling noise
Are you sure its not detonation?noise only in boost?
Old 05-04-2009, 06:17 AM
MURF, Thanks for your reply,
The rattling noise only happens when I push the gas pedal @ about 2000rpm or under @ operating temp either when the car is moving or not moving.
Yahow
Old 05-04-2009, 06:58 AM
Noise
Tap the cat to see if its partially melted down ..the scavange pump drip shield against the scavange pump line is common rattle
Old 05-04-2009, 07:16 AM
Noise
Vacuum leaks sometimes sound like metallic tapping (but not really "rattling") and come and go at different temperatures and rpms. Try to duplicate the conditions where the noise occurs, stick one end of a section of vacuum hose up to your ear and move the other end to where you believe the noise is coming from.
Or, duplicate the noisy condition and use a propane torch hose/wand, deliver a small amount of gas near the noise. If there's a vacuum leak, the engine will suck it up and the idle will change. Be careful! Make sure that you have no sparks or other sources of ignition nearby.
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Old 05-04-2009, 12:36 PM
mark houghton's Avatar
Originally Posted by Yahow lam View Post
Hi,
Lots of good ideas on where to look so far. I'm intrigued by the location that you seem to hear this from. Do you realize that directly behind and below the boost recirculation valve is the turbo oil scavanging pump, driven off the left side cam? I wonder if something is amiss there. Are you still operating with the emmisions air pump, which drives off a sprocket back there? Just a thought....
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 05-04-2009, 02:15 PM
Hi Guys, Thanks for all the good ideas to where to check and I will jack the car up to check the underneath as Mark suggested as well.
I will report back to you guys when I find the problem.
Yahow
Old 05-04-2009, 07:39 PM
Hi,
I found the rattle problem by removing the fan belt, discovered a 1"x1" black plastic cap stuck under between the fan pulley and the shroud, I don't know how that thing got in there and what that plastic thing is for, but after I removed it and drove for about 50 miles today no more rattling noise!
Thanks a lot for all you guys help.
Yahow
Old 05-09-2009, 10:25 PM
WERK I's Avatar
Could it be the black plastic nut cover that goes over the pulley/alternator shaft nut? It just slips over the nut for ornamentation.
Dave
Old 05-10-2009, 06:24 AM
Hi Dave,
You are right on, after I read your reply I went to try slip that black plastic cap on to the pulley nut and it fits perfecfly, I am not going to put it back on and it is going to the trash can.
Thanks, Yahow
Old 05-10-2009, 09:31 AM
WERK I's Avatar
I suspect someone left the cap laying around the engine somewhere during maintenance and forgot to put it back on. The turbulence and vibration dropped it in there.
I've had mine on my engine for over 20K miles and it never came close to coming off.
Dave
Old 05-10-2009, 10:05 AM
A930Rocket's Avatar
You would be amazed at what gets sucked in the fan as well. I've seen shop racgs and paper towels get sucked in before you could move.
Old 05-10-2009, 07:50 PM
