Long story short, the engineers at Garrett (and BorgWarner, etc.) have the tools to refine their products very well before putting them into production. They don't match one compressor wheel to a different turbine wheel by chance or accident. They look at the airflow characteristics and inertia of the components and put together the best combinations. Rarely will you find a manufacturer's turbo with a compressor wheel that radically out-flows the turbine wheel, as you often find in the aftermarket. (And these are usually targeted for small displacement, high boost, high HP engines that also run massive wastegates to make up for the lack of turbine flow.) That's not a 930 engine's m.o. One result of this mis-matching is higher exhaust backpressure at the turbine inlet (header) flange. 930s are bad enough, and the long, undersized tube feeding the wastegate on most aftermarket headers doesn't help matters, either. Anyone else have exhaust backpressure data they would like to share? We just dyno tuned an ex-Ruf 3.4L that had been in storage for many, many years. Another shop converted it to EFI and "600hp" -- not with a K29-7006#13, buddy! At 17.2psi boost in the manifold, the exhaust backpressure was just a hair under 30psi. About a 1.75:1 pressure ratio (backpressure:boost) despite the larger #13 turbine housing. Car is choking on the backpressure, spooling up slowly, keeping the Group B cams from doing their work. One of the most responsive EFI 1994 Turbo 3.6s we have built had 2 different large ball bearing turbos. The first had a 1.4:1 backpressure ratio and drove great. The next turbo we used had a lower 1.2:1 ratio from a significantly larger turbine wheel -- and it spooled up even sooner than the smaller turbo! Quote:
What's the most power anyone has made from a K27? The most I've ever seen was 455hp from a 930, and that was on MODE's (Holcombe's) engine dyno. 3.5L 930 with all usual bolt-ons and cams, and a K27-7006. It made the same power at 1.1bar as at 0.9bar -- 455hp -- only at lower rpms as boost was raised. End of the turbo, turn the boost back down, no point raising boost when the turbo is out of air.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Crotchety Old Bastard
The stock 7006 is an old turbo and comares in no way. You can get 400HP out of a 7200. Much depends on how the engine is built or set up, then when the turbo runs out of air.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Ingenieur
I can't believe how many Excellece Magazine bikini models have PM"d me since I posted that turbine map. Who would have guessed!
E-85 sippin drunk
Well Played, my friend, well played!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Would a larger diameter header (say from the standard 1 5/8" to 1 3/4") help to reduce the backpressure? Or is it something else? thanks!
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Too big headers would probably only increase the lag as you would loose pulse energy in exhaust gases and only feed turbo with pressure delta.
Thank you for your time, |
Hi Goran,
That's very true, the turbine blades are the major cause of backpressure. But I have also seen modified engines wake up and become more responsive, more powerful when removing headers with little 1.5" OD primary pipes and going with larger 1.625" or 1.75" primaries and larger secondary pipes. On a mostly stock engine, or something <400hp, I don't think the big 1.75" headers make sense, no.
Out of curiousity, do you have a rough rule of thumb of what frame size Garrett to use on which 930 engine combination? For example: GT35r 450RWHP-550RWHP GT40r 550RWHP-650RWHP GT42r ? -?
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
A fellow Pelacanite
I have always wondered about back pressure with the K27HFS due to the larger compressor side vs the hot side.
I have always wondered if the fact that because the K27HFS turbo will make more volume of air from the cold side (compared to a standard K27) at say 6000RPM (or a given amount of flow through the turbine) this would therefore mean that because the wastegate would need to be open further that this would reduce backpressure just before the hot side more than it would for a standard K27? Did I get this wrong apart from the WG having to be open further/longer/more often?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 08-23-2009 at 09:37 AM.. |
I wish we would start checking the back pressure with different turbos. This is such a basic concept.
This post talks about ballanceing the hot and cold side and suggests that there is significant opertunity on the hot side. And that it is not alwas a small turbine that makes for the quickest boost. Nor is it the bigest that makes the most HP. Quote:
We'll be datalogging EBP (Exhaust Back Pressure) on each of the EFI 911 Turbos we're working on (3.5L, 3.4L, 3.3L, 3.5L, 3.8L) and can post some data over the coming weeks as the projects hit the dyno.
The turbochargers range between GT35R and GT42R in size. Sorry, no K27-7200 based turbos in process.
I’m waking up this old thread since I’m about to embark on a change from a K27HF2 to a GT35 Gen II that I picked up from a fellow turbo enthusiast who had it laying around new in the box and I’m looking for information. Chris at TurboKraft is helping me with a turbo housing and oil restrictor since the good deal turbo didn’t come with that. Good info here on water cooling ports since I didn’t know what to do with them and now I know to leave them open.
I’m not looking for more power, just less lag and hopefully better drive ability. Plus I haven’t done much to my car since I finished the engine rebuild and EFI project over 10 years ago and l’m jonesing for some garage time with the 930! ![]() ![]()
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Just as a data point, I have had my TK GT35r in place for several seasons now with no issues and while enjoying much better power delivery than any turbos used in the past. No operational issues at all so far.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
2019 turbo choices? So what are some turbo choices for today.
CIS up to 450 h.p. EFI over 450 h.p.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
K27-7200 based:
Upgrade yours to double billet internals -- billet compressor wheel, and very lightweight high-flow turbine wheel. + Good for all-out CIS or mild EFI builds. + Exact bolt-in fitment because K27-based - Limited by that turbine housing -- backpressure on 450+hp EFI engines - Replacement housing parts are practically non-existent. Need a new turbine housing? Good luck, indefinite backorder, if not simply NLA. Garrett: The GT35R is still the best all-around turbocharger, more responsive than a K27 and flowing more cfm than CIS will reasonably support, capable of 620whp on EFI engines. Their new Gen2 GTX3582R has a lighter billet compressor wheel and increased efficiency at our low pressure ratio so finally, the billet wheel is a worthwhile upgrade over the cast wheel. Also, still highly configurable, ex: different A/R turbine housings, v-band outlet available, T3 or T04 or v-band turbine inlet, etc. BorgWarner: So far, the EFR's haven't performed well enough to justify their expense and additional custom fabrication. Some guys still swear by the S300 series (think Tippy is running that).
Chain fence eating turbo
But, I have the Joe Schmo S-series, the S366 (66mm comp) to be exact. That turbo spools stupidly quick for having a gargantuan turbine (73mm exducer). Some here used the S360's (60mm) but weren't raving about them, so there's that. The boost recovery is insane on mine. I put a YouTube video showing my idiot light indicating 1 bar on the boost gauge. You can see the light illuminate nearly instantly between shifts. I think the S362 would be sweet as it's right there in size with a GT35R in compressor size. How quick does the S362 spool compared to the GT35R? Dunno. But, if the GT35R is too far out of reach, the S362 may work as a cheaper alternative.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
What about the 7006.
How do you like the Gtx3584rs?
and I'm looking for a old kokeln turbocharger.
You do not have to send it to germany - just to Huntsville Al. many thanks |
