Mark,
That info is in this thread early on I believe. I know we have the vac advance curve and I think we have the mechanical advance curve. They just need to be layered against the base timing spec. From memory I think with a stock car we start at about +1 at idle, instantly go to about - 7 with loss of vac, we then have about 18 deg of mechanical advance that comes in on top of that in a linear manner and is full in by about 3000rpm putting us at about -26. Boost retard is about 8 deg and pulls us back to about -16. I forget when full retard comes in by but I thing it is in the post somewhere as Chris figured this out on a Sun dist system. I believe it only takes about 5 ps to get full boost retard. I am thinking that is a bit fast and is limited by the amount of spring pressure that can be used for vac-retard. Having a boost signal to both sides of the pot might slow that down but we know it should be fully retarded by about .7 bar. I know this thread has a lot of extra stuff in it but I think this basic part is in the first page or two and repeated throughout. I could be wrong. |
Keith,
I pretty much concur with your last couple of posts. While going through all this I have tried to practice due diligence in arriving at what I feel is the optimum timing I'm going to run. I have taken into consideration the specific mods I have and feel safe with my conclusion. To hedge my bet I have personally spoken to four of, what I consider, the best 930 tuners in the USA. The interesting thing about this is that the four opinions are within 4* of each other on max advance at 4000 RPM and 1 BAR of boost. All four gave the same 4 prerequisites before offering an opinion on timing. 1. Fuel system condition: proper system and control pressures, injector flow and pattern even, and fuel pumps pressure in spec., and most importantly "Premium Fuel Only" 2. Larger intercooler ie. factory C2 or quality aftermarket 3. Free flow exhaust system 4. Fuel head modification, adjustable WUR, DWUR or any other form of fueling increase that can consistently maintain afr's under load between 12.3 and 11.5 On the subject of timing all 4 recommended 10*- 20*BTDC of initial timing at idle. (Either block off vacuum advance/retard and set initial timing at 10*- 20*BDC or leave vacuum advance/retard connected and add sufficent timing to get the 10*- 20*BTDC off idle) 26* BTDC (US & CA) 29* BTDC (ROW) (No load 4000 RPM Vacuum Connected) 16*- 20* BTDC at 4000 RPM and 1 Bar of Boost If you look at the opinion of the experts we were pretty well on target with this thread. The one thing I may have exception with is following BA's suggested timing recomendation. When Bruce wrote the book there was no way to control afr's and that ability alone makes a drastic difference. I'm presently reading through the documentation for my new model DWUR and this thing is amazing. You have the ability to set control pressure every 250RPM based on RPM and MAP. You now have the ability to program out all the rich or lean condition that drove 930 owners nuts with the original non adjustable CIS. This advance alone will make lean condition detonation a thing of the past. Cole |
cole, thank you. thats good info for us EFI and you cavemen ;) dizzy folk. I love this thread
dr,
That exactly what Wayne intended this forum to do. All of this thread is a result of hashing and rehashing, opinions and exceptions from a lot of good people and good friends. Ya gotta love these bums. AIN"T AMERICA GREAT !!!!!!! Cole |
J,
Been meaning to let you know. MSD sells timing tape in packs of 8 you can find it on Evilbay runs about $4.00 covers pully dia. up to 8". Cole |
Dave,
Sorry I hadn't clarified that earlier. I directed all my research and posts toward us Smucks that can only afford bolt ons, and usually, one at a time. My car has been a 7 year modification project that started with a written list and 3 stipulations. My stipulations were: 1. I had to finish designing and building my wife a new house. ( My wife happens to be the sweetest soul God ever put on earth and I most certainly do not deserve her. ) 2. No mods that require engine disassembly. 3. Everything done had to be paid for with disposable income. ( I cheated a little when I tried to convince my Insurance Co. that my DWUR was a new implantable chemo pump ) My wife's house is done after 5 years on nights an weekends ( It is known, in this small ultra conservative Indiana community, as ("The Weird House") The "Old Sled" is on track for it's tire smoking debut on my birthday Mar. 17 For all reading this: I would like to further promote the listing of your cars specs in your signature. I have found it very informative in doing comparisons when considering further modifications and I think others will also. Cole |
When you take the boost out of the equation, notice how similar Cole's timing numbers are to a modern performance small-block Chevy:
Ignition Timing for Better Fuel Economy - Strategies & Techniques - Rod and Custom Magazine |
Dave,
You mention pulling timing back 5-8 deg with twin plugs. That seems to about right on a normal aspirated motor. For reference a 3.2 at 5000rpm seems to be -18 to -24, a higher compression 3.6 with knock sensing seems to be about -15. From personal experance my 2.4S at 9.2 CR I ran about -33 deg total advance. On my 2.8 Twin plug w 10.4/CR I ran about -25. However, under boost on a 930 the timing may not be different at all between a single and twin plug from what I think I have been seeing. I suspect this might have something to do with the more open chamber design of a 930 that dose not put a high piston dome so much in the path of flame propagation and the high effective compression achieved under boost that accelerates the combustion process. Pre boost is a different story. Twin plugs offer a solid advantage on a 930 by increasing pre boost TQ up to 5%. Further they can make for better assurance of proper combustion of a mix that can be difficult to fire because of the poor AFR's (lean) that can come with CIS combined with very low effective compression that is exaggerated almost one point lower with sport cams. I find it interesting that RUF did not twin plug there Yellow Bird nore did Porsche there 993TT which were both pretty much open budget cars. However, Porsche twinpluged all there 3.6 high compression air cooled cars. |
Mark,
We were talking about advance on boost. Another approach. Euro timing is -29 deg at full advance, US is -26 at full advance to accommodate fuel differences. Boost retard is 8 to 10 deg per Chris's test on dist machine and the factory curve posted early in this thread. Thus, full boost timing from the factory seems to have ranged from -16 to -21. I guess we would have to think this is conservative settings to allow for variations in tune and environmental factors that can not be compensated for with CIS and mechanical distributor. Euro 930's w stock Intercooers and mostly in-efficient turbos by today's standards that were spec'd up to .85 bar boost. A stock 930 on a summer day running 1 bar may be in trouble at -14 on boost, a well built turbo on good fuel ruining .8 bar on a cool day with cams might be happy with more than -21 deg advance. I guess it depends? http://forums.pelicanparts.com/suppo...leys/pint1.gif |
I believe Ruf and Porsche did not twin-plug because their budgets were not open-ended. Twin-plugging would have required more finances in developing ignition systems completely different than the NA engines. Their decision was budget-based, not performance based. In other words, "bang-for-the-buck". My $0.02 |
Keith,
Again I want to reintegrate my comments previous regarding afr control that never existed before. I think we are just now going to see what is capable with CIS because of these advances. Consequently much of what we have been discussing here is, although perfectly valid in the past, may not be totally applicable in the near future. If you look at the ability to change control pressure on the fly every 250 RPM past perceptions change quickly. Bruce Anderson's comments about increasing boost were very valid in there time but I feel this new technology may significantly change what can be done. Dr referred to us as Cavemen and I got a real kick out of his comment because I am. And I'm proud of it. I cannot express the passion I have for this 30 year old, 2800 lb., tub I lovingly call the "Old Sled" and I will die with her by my side. Like everyone here I want to get the most I can out of the old girl and we all know there are better alternatives out there now but no matter what alternatives there are it could never be the same. I am lucky enough to own a automotive Icon that set the benchmark for every Marque that followed and it's truly the original supercar. No matter what is to follow the original Porsche 930 is the one that started it all. I've owned this old girl for 22 years and I still find myself opening the garage door before I go up to bed just to look at her and so I will strive to give her more always knowing she will give more back. Cole |
:) - i did mean it with all due respect to the guys keeping the essense of these machines alive.
And it's great that no matter what our own personal idea of "my dream car" is, we all chose these little monsters. I love my 930 and want to give it every chance to accel (pun intended) in life... |
Hello !:)
I am happy to share with you the measurement I made on my C2T with it EZ69 ignition... I installed an USB scope to my mini PC . For this measurement I connected the flywheel trigger on 1st channel and the ignition coil input on the 2nd channel. Thus I was able to measure the time delay and calculate the ignition advance. ( the reference is given by the idle advance which is equal to 0° ...it has been controled ) here is the recorded data during a 3rd gear pull http://img20.imageshack.us/img20/672...tionavance.jpg Then, here is the advance curve http://img188.imageshack.us/img188/2...ureavance1.jpg The ignition timing is about 25 - 24° under boost. The ouput of the EZ69 is totally stable as soon as the boost pressure reach or exceed 0.6 bar . There is absolutely no knock on my engine (verified by sensor) and I run about 1.2 bar (with SC cams), AFR 12.5 at the TQ peak .( 60mkg) Don't you think that your suggested ignition timing under boost ( I read somewhere 16° under boost ) is too much conservative ? |
You got skills my friend!
12.5/1 AFR, 1.2 bar, 25deg advance, wow? That is more advance than any modern factory air cooled normally aspirated 911 seems to be running under WOT including the 993, 964, and 3.2 Carrera. Also the AFR is leaner than most the air cooled turbo experts are recommending on an even an EFI 930 turbo at those boost levels. Still, very cool and a good data point for pushing the envelope. |
I, too, suggested that 16 is quite conservative a few post back. I run 25 under full boost and the engine just loves it. I'm only running .8 bar right now and it is scary fast. I ran this same timing before I went "slippery slope" with my motor and there was not any physical signs of detonation: no pitted pistons, no broken rings, nothing. |
As to the advance , the porsche workshop book is mentioning 21° +/- 3° if the EZ 69 is triggered with 1.75 bar of absolute pressure ....so a 24° degree is in the normal tolerance range. ( and my measurement can also include some tolerance) And as mentionned previously ,if installed, the FVD plate bring 6° more and doesn't bring any detonation or knock under 1 bar with opened ports & 964 C2 cams !!! You don't want to believe but that's a real thing ! As the AFR, for track and very hard conditions, it would be better to drop it arround 11.8 or less. But for road use , sincerely it is too rich for stock or midly modified C2T car. Do you ever make an inspection of the spark plug with a 11.8 averaged AFR ( As I ran during 8000 km) ? Do you think it is a good thing to adjust an AFR to 11.8 at high RPM while the intake/cam/ turbo are out of breath ( but measured boost pressure is still at 1b ) ? Have you connected a device to check under which real parameters (into a given setup) the knock occurs ...?;) |
Good stuff, Thierry. Unfortunately I haven't a clue on the differences for a C2T vs. my '87 930. I would be very reluctant to run 25 degrees advance on my car at 1.0 bar boost. Maybe 18, or on a nice cold winter day and fresh high octane gas maybe 20. I can't believe you're getting away with that timing unless your compression ratio is something like 6:0:1. It's worth thinking about!
Viva la CIS and those other nutts that love it to!
Thierry,
No. I do believe you and applaud you. You have got this stuff down and I wish I had some of you skills. You also have better fuel and weather at your disposal. There is a difference between street duty and track. Your success in doing helps us to question how far we can go. To offer a sobering thought, I knew of one stock 89 930 that ran 1 bar for a long time on the street. Then one day I saw his motor all over the work bench after he burned a piston. Worked great for years. Then it was a hot-day, or he had a dirty injector or something... It is just how far one wants to push the limits. I know the water cooled turbo guys run those types of values often on even a higher base compression. when I had my dyno work on my C2T the guy wanted to stay around 12.2 AFR. No I accept one EFI 930's suggestion that a EFI 930 running the fuel we have available today should stay to the rich side of 11.8 AFR. With CIS I might be a bit richer than that. I still have no idea how far we can push the advance on boost. I just have a good idea where the factory came in on the 930. Keep up the good work. |
Thierry, what fuel do you use? V-power 100 oct RON? Nice gadget that USB scope. Do you have more info of it?
Thanks for the info Cole...
I was thinking of calling MSD about that but havn't done that yet. The tape for a 5.25" diameter pulley is cheaper than buying another timing lite with the advance delay dial on the back. Jim Quote:
Jim,
My old Mac Tool timing lite croaked last week. Found a special going on Amazon for Equus 3568's for $60.50. That's a good buy and it will be here this comming week. Cole |
I've heard some timing lights are fried by MSD ignitions even though they are induction triggered.
Maybe the MSD multiple sparks below 3000rpm are too much for some of the older ones and they need something to buffer the signal to hang with it. Jim |
FWIW my Equus 5568 works fine with all my MSD 6A equiped vehicles, so I'm guessing the 3568 would do fine. |
Guys,
The Old One needs some help here. My age, stubbornness, and total distain for computers forces me to ask; could any of you tell me what hardware I need at the usb port on the DWUR to communicate with my wireless laptop. Before you start pimping about my lack of computer skills you have to understand I took my college final in Statics with a slide rule and I still have the first TI four function calculater. Jim & Win, The MSD did not get my timing light , it was a Chevy pick up. My buddy managed to back over it. He was bumping the ignition to get to TDC and left the truck in gear. Cole |
MSD timing tape ebay search result.
I could probably just print this at the correct size/resoloution, cut out the bottom strip or resize the top one and try glueing it on... http://forums.pelicanparts.com/uploa...1260132359.jpg If thats not right I can clone out the MSD logo in p-shop and resave it in about 3 seconds. |
You ought to sell the TI on Ebay....probably worth - well, nothing. Or put it in a time capsule and bury it in the backyard. |
Anyone have a step by step with pics in how to modify the limit on the distributor internals .
Thanks |
"The MSD did not get my timing light , it was a Chevy pick up. My buddy managed to back over it."
lol... don't ya hate it when that happens.. "Anyone have a step by step with pics in how to modify the limit on the distributor internals." If you take it apart you'll see what you have to do. There's 2 pins on the mechanical advance plate that fit into slots on an adjacent plate that limit how far the advance weights will advance the breaker plate, reluctor, or whatever it's called in an electronic distributor. Last time I did it was on an old points type bosch euro distributor on a BMW. You can put bushings on the pins to make them thicker and as long as they are not too thick to fit in the slots then that will limit their travel in the slots, or you can put something in the ends of the slots to shorten them and limit the travel of the pins. It's made of steel so you could braze some brass into the slots and regrind them with a 1/4" carbide burr in a die grinder to the length you want. That would probably be alot of trial and error and repetitively removing and installing the distributor until you got it where you want it. An ebay deal on an MSD 8762 BTM may be a more attractive alternative and you can adjust the timing under boost from inside the car on the fly. There are 2 models of the MSD Boost Timing Module. One is for MSD ignitions and the other is for OEM and other CDI's. With a loud muffler or zork it may be impossible to hear trace pinging while the windows are rolled up under full boost if the timing is too far advanced for the fuel octane, boost, and temperature conditions though. |
My Dad gave me one when I was young, and I actually learned how to use it. |
I am using EURO 98 fuel. As to the scope, I bought a "PICOSCOPE 2204 " You can see it on the following link . PicoScope Ultra-Compact Oscilloscopes from Pico For those who are interesting to make similar measurements, the flywheel trigger must be connected via a differential sensor or via the "hot" (+) output only... the (-) of the trigger can not be connected to the ground . ;) |
"could any of you tell me what hardware I need at the usb port on the DWUR to communicate with my wireless laptop."
I remember people saying the DWUR uses a serial port connection, or maybe it's just the early versions. Strange they used that since those have been kinda obsolete and usually absent from laptop PC computers for a few years now. I think you need a serial to USB port adaptor. It's a small passive device and i don't think they cost much. |
Hello Keith Sorry, maybe I misunderstood your last post. Something I can tell you about the AFR. As said, I ran about 8000km with my car since I made the setup ( and engine rebuild) . My AFR was adjusted arround 11.8. Recently, my workshop inspected the spark plug. It was really black with few little stain of not complete combustion. Just after this inspection, I changed my datalogger ( which was deffective for EGT input). So after changing, I was able to measure the EGT. So I made both 11.8 and 12.5 AFR test.... The EGT is decreasing a little bit at high RPM ( beyond 5500 rpm) while I tried 12.5. ( So the EGT is higher with 11.8). However, the EGT doesn't increase on the max torque range ( from 3700 to 5200). Most of people ( me either before) think it is a good point to decrease AFR to nearly 12 until the red line ( 6500). At present time, I suspect Porsche got some good reasons (considering the original timing at high RPM) to adjust the original AFR to nearly 13 at high RPM. Past the max TQ point, I think the air filling in the barrels is low. As the iginition timing is also a bit low, it is probably not a good thing to increase AFR... As to the fuel, I don't know what is the standart in US (Sorry for my poor knowledge) . Do you have fuel similar to EURO 98 ? As to the weather, we reach about 35°C during summer in my province... it is true that during days at those temp, I don't like to pull too much my engine. As you , I like the CIS !!!!!!!!!!! :p:p:p |
No my compression ratio is strictly stock . As said before, I use standard EURO 98 fuel. I do believe the detonation or knock are much far away from the usual beliefs. That's probably why some tuners can reach such high torque and power (I speak about 500 to 600 HP ) . There is no secret..... they fill much more air inside the barrels (with more fuel of (course) ...and they are still using ignition equal or superior to 21°.... So using a 25° or more on a midly modified C2T/930 can make sense. Having said that, we all know here that a power/ torque increase always decrease engine reliability !!! |
98 octane fuel? 93 is the highest available in my town. |
"Do you have fuel similar to EURO 98 ?"
Unfortunately the highest octane pump gas in the states is 93. Big difference from 98 so that alone lets you run more advance or more boost or a little of both. ************************************************** ************* Mark and Cole, if you see this I did more short duration 3rd gear full boost 1.1 bar acceleration runs on the interstate last night with the windows up so I can hear the motor good while it was about 70 degrees out. The intercooler was not heat soaked and gas is Chevron 93 octane pump gas with "at least 10% ethanol" here in S. Florida. I have a modified Imagine Auto/Flowtech USA fuel head and B.L. adjustable WUR keeping it sane with high boost control pressure's so my AFR's are a little richer/safer than stock up there. I don't put my cars specs in my profile so it always shows in a post, so I'll mention the car has a half bay garretson long neck intercooler on it and k27 7006 turbo with manual boost valve controller and 964 cams which have more lift, different lobe centers, and a little more overlap compared to SC cams. At around 5000 rpm I could hear the beginnings of faint trace pinging from the motor with the MSD 8762 BTM boost threshold or start point set to 5psi and pinging started with the slope dial set at 1 degree retard per psi of boost. When you hear the begiining of trace pinging that means advance is on the edge and is as far as it should be allowed to go. As you know any more advance will not make any more power and will eventually hurt the motor. Turning the boost retard slope knob to halfway between 1 and 2 degrees per psi of boost made the trace pinging go away and I couldn't hear any pinging or detonation but these were short duration 3rd gear runs because you come up on I-95 traffic in front of you quickly. Anyway, the short version is we both have the same year car with the same distributor. The distributor is turned clockwise and advanced as far as the adjustment slot allows, both vacuum lines are hooked up, the MSD 8762 retard start point is 5psi and the seperate boost retard slope knob is at 1.5 degrees retard per pound of boost for the best performance I've gotten so far. I still havn't put timing tape on the engine pulley and pressurized the 8762 hose nipple with 15 psi and held the motor at 4000+ rpm with a timing light to see what timing actually is, but I eventually will.. If it was summer hot out I may be safer to leave the slope knob set to 2. I like having the fast acting slope adjustment in the car on top of the autoheat box. Next time I have the intercooler off I'll remove the distributor and lengthen the adjustment slot in the advance direction a little so I can try more initial advance, then set the slope knob to 2 and try that. With slightly longer duration cams like 964 compared to SC or stock, the intake valve closes later in the beginning of the compression stroke so static compression is lower, (but at high rpms with ram effect [and boost] it becomes higher) and you can run more initial ignition advance than a motor with shorter duration cams because of that. |
Jim, Win, and Mr. Gimpy
My dad did the same with me but he took it away because I was in the 5th grade and was doing my homework with it. He told me I need to memorize my multiplication tables before I could use it. No leather case on the belt or nerd pack in the pocket. I was the only guy in the class with a leather jacket and and old junk Harley Springer for transportation, Now that I remember times like that, I guess I have always been socially unacceptable. Jim is making me Jones for a 930 fix. It's been so long I can't stand it. I may have to come see one of you guys and bribe you with beer for a ride. Cole |
