Pulling the inner vac line is like having the solinoid in cold start permenatly. This blocks the vac-retard and thus advances timing.
If your car runs well this way dose not seem to be any risk. However idle timing should come in more like -15 or more, if the dist is advanced to its stop and the vac-retard is disabled. |
Running with the vacuum retard line disconnected and the distributor turned clockwise in it's slot all the way makes idle timeing advance too far on my car.
The idle becomes higher of course, but also rough and kind of nasty. Not knowing what the actual timing under boost would be if you did that could be a very expensive risk. |
Jim,
Your car and mine are both running about the same from what you've described, and we're both able to get no more than 8 degrees advance by twisting the distributor to the max (with the vac retard hose connected). And neither of us are using the vacuum retard solenoid. Your settings: Start retarding at 5psi and the seperate retard slope control knob mounted in the car is currently set to retard timing 2 degrees for each pound of boost. You should see all 8 degrees of added advance being removed by 9 psi of boost, and another 7 degrees retard by 12.5 psi. My settings: Start retarding at 2psi, and retard timing 1.5 degrees for each pound of boost. This should result in all 8 degrees of added advance removed by 7 psi of boost, and another 7 degrees retard by 12 psi of boost...for a net total of 15 degrees. I was being conservative when I first installed the BTM, paranoid to where I wanted all the excess timing removed by the time I was halfway into maximum boost, and I stopped messing with it until gaining a bit more knowledge. I think your settings are more appropriate, not being concerned with the extra advance until 5psi, then shaving it off quickly after that. And I think you're correct in your observations that more timing on boost doesn't result performance gains, but rather engine damage risks. Get as much timing as your car can stand early on for low/mid range power, and get rid of it by the time you're half way to your maximum boost. One more thought, that I started experimenting with before I put everything on hold (with a broken foot). The BTM will continue to remove timing as it continues to see boost pressure rise, up to a maximum of 15 degrees. So in both examples above, what we're actually seeing on full boost is probably 7 degrees less advance than running without the BTM. That may not be a bad thing from a safety standpoint, but may leave some power on the table. I put in-line with the boost pressure line to the BTM, a pressure regulator that won't allow the BTM to see any more than 8 psi of pressure. That way, I still get all the 8 degrees removed by then and no more removed as boost continues to build. Not sure of the impact yet since I've done but one run with it, but in theory it makes sense. |
Advancing the timing at idle until the idle becomes choppy can't be good for the rod bearings or piston ring lands.
The choppiness is caused by the mixture being lit off too early before TDC, and that would be loading the rod bearings in a bad way before the piston reaches top dead center.. especially while the oil pressure is low at idle. I've played with bosch distributors alot on old 4 and 6 cylinder BMW's in the past and advancing the timing at idle too far makes them idle rougher too. |
Thanks, you and Cole are the one's that inspired me to do this and it does make the car a little stronger at low speeds and especially getting away from a stop when the turbo isn't boosting. |
MSD recommends setting the 8762 retard start point at 2psi in the beginning of tuning but I think the majority of people installing these things are on supercharged drag racers with higher compression than the 7:1 in our cars, so I think the 2 psi retard start point is conservative for a 930.
With the windows up so I can hear the motor better during full boost acceleration I don't hear any ignition knock sound, pinking or pinging, or detonation of any kind so I think the 5psi start point and slightly steeper retard slope curve works OK for the low compression 930 motor. I don't know if the final amount of ignition retard is the same though. When I turned the knob to around 1 degree retard per pound of boost under full throttle, 5000rpm and 1 bar boost I begin to hear what I think is some ignition knock (but none of the higher pitched crackling pinging or pinking noise of detonation) while there doesn't seem to be any more power increase going on, so I quickly turned it back to 2 deg retard per pound of boost and the faint knocking noise goes away while the car seems to keep accelerating just as quickly. Retard the knob to 3 degrees per pound of boost and I can feel some power go away. |
HMM, interesting you guys mention higher idle timing causes a rough idle. With EFI, the more timing I threw at it - the better (smoother) it idled. I'm at -20* advance at idle right now and my idle rpm moves less than 50rpm while sitting still. When I tried -10* it seemed to be unstable and very sensitive. My cruise timing is around -28*
What is your idle AFR?
A slightly rich idle mixture will be unstable and oscillate up and down with stock igniton timing at idle but advancing the idle timing will even out and stabilize the idle even if it's richer than needed. I have my idle AFR right around 14:1 steady cruise up to 3000rpms is around 14.5:1 |
Using the timing change that comes with a loss of vac to accelerate the motor seems like it might be beneficial in it's own right.
Just because a motor can handle more timing at idle w no load dose not mean it can use it under load as it begins to accelerate the motors mass and then the car. I have reason to believe these motors can take as much as -23 at 1000rpm at idle with no load. However, under load no more than about -16. By 1500 something like -23 with no load / no boost but only about -20 at .2 bar under load. Thus something that starts at or jumps to -16 should be good off idle and we should be able to use about -20 by 1500. ---- For those not using MSD I believe there is off idle throttle response and on cruse efficiency to be had from modifying the Boost Retard stop that limits the range of motion of the pot. This would increase the level of boost or vac retard for more advance off idle and more advance on cruse while keeping the same on boost timing value. |
Mark and J,
I'm as confused about all this as you two. This Ultimate thread has made me crazy. I'm going back to what I know and what I don't know. One thing for sure is I have no idea what my distributor really does or doesn't do. Then when you add boost anything you thought you knew about timing goes out the window anyway. I will say I'm pretty confident that at 1 bar your timing needs to be between 18 -22 degrees. But this is also true only if you are still running stock compression. I have looked at numerous equations to see how to figure effective compression ratio at 1 bar and decided it would take a seperate computer to run the correct calculations and then only if you know from another computer what all the 108 variables are as they change under load and boost. Anyway I decided F--- it I'm going back to basics. When I was told I had cancer everyone around me went nuts. My sons in law even drew straws to see who got to buy the "Old Sled" once I croaked. I thought about it and just figured we're all going to die of something and cancer is pretty simple, it either kills you or it doesn't, and a 50/50 chance is pretty good. You just gather all the information you can and you do everything you can to beat it and either you kick it's ass or you go out swinging. I happen to be the most bone stubborn SOB on earth and I don't have any quit in me. So I've decided this modding a 930 is much the same, the d--- thing is either going blow up or it's not. If you don't have the balls for it then don't go there. If your going to go there then gather all the information you can and use it to give yourself the best chance of keeping the heads on it. After all the factory ran these motors at 1.4 bar flat out for 24 hours. After all this s--- it still boils down to one thing, detonation. If you can control detonation you can safley run .9 to 1 bar without incident. We alredy know a lot about controling detonation and we need to put these safegards in place before you start pushing the envelope. (Oh GOD NO .... I just opened the door for another commercial advertisement from John at J&S) Does anyony know if he even owns a Porsche? If you are even considering changing to a higher compression ratio, know you better be prepared to spend 6-8 grand on preparing block, crank, rods, cams, pistons, and fasteners even before you start looking at heads, ignition, and a fuel system. So before you ever start down this slipery slope you need to determine how you are going to use the car and be realistic about it. Reaper930 has the ultimate weapon when it comes to turbocharged Porsche street cars but I'm betting you could not build it for less than 150K. And once it's build maintaining it is like pouring buckets of bucks off a bridge and it would be awful to drive on the street full time. I think it's the knat's ass but unfortunatly I can't afford one so I just remain green with envy. I've always known what I wanted. A neat, clean 930 with 375-400 HP that's fun and easy to drive on the street and fast when you want it to be. I have also known what I needed to do to get there, starting with controling detonation. I bought the car with 52,000 miles, SC cams, light porting, and a K27 7200. I immediatly bought a better intercooler, 964 bov set up, a good set of headers and I always run the highest octane fuel I can find, without exception. The intercooler, headers, and fuel octane are three of the four, must do, things to control detonation. The fourth and most difficult is fuel system control. You HAVE to know where your Afr's are at and you Have to be able to control them. I've gone with an Innovate LM1 and I'm going to be monitoring afrs, rpm, MAP for boost and vacumme, EGT at the collector Y, MAT for intercooler and manifold temp, CIS system pressure, CIS control pressure, and on board afr readout. As near to an in car dyno as I could get. I can download all the information and tune accordingly. The tuning is the tough one, you HAVE to be able to control the afr's, so here comes the dwur, adjustable wur, or andial with a clamp. If you don't have one of the latter all is for nothing. At this time I'm not going to worry about timing because there is no way to get it right without a Dyno. I'm going to start with 10o of advance and 18-22 o at .8bar, once I get the afr map done I will play with timing. I bought a MityVac and I took a blood pressure cuff and a 15 lb go kart tire gage to make a boost simulator. I have a digital timing light with adv and retard dial. I can screw with the timing then without worrying about detonation. Don't know of any better way to do this but I'm always open for suggestions. Cole |
I feel your pain and I am with you 100%. The factory pieces were designed and manufactured to do one thing......work very effectively and reliably with a stock engine. Change fueling, boost, VE, ignition without safeguards or monitoring and you're "dancin' with the devil" my friends. |
David,
I get such a kick out of all this, I try to read everything I can and then sift through it to get the fly s--- out of the pepper. Always assuming I'm going to walk away with some valid enlightenment; that's what makes this site so great. All you bums kept me going when I was doing 6 mo. of chemo and sitting here at 3 am with a bucket between my legs and I love every one of ya so don't take this wrong. I have read 333 posts and still don't know exactly what my factory distributor specs. are and have no real idea what the timing curve should look like. But hay !!! Keith is way to serious, Mark is as twisted as I am, and J keeps me grounded but all in all it keeps me from robbing banks or something. Cole |
Last night I started the car after 7 days and before i could back it out of the shop a plug fouled :( as it was warming up in the high 11's a/f (still haven't fine tuned that) |
Are you seeing a lean surge with first throttle? I believe off idle there would be more TQ at around 13/1. Same off curse till boost comes on. That is one of the reasons why 3 to 3.5 CO seems to work well. Not great for MPG though. |
Which #60s do you use? Mototrons have become problematic after the change of manufacturer. The quality has gone and IIRC they follow the spec only at 3bar.
For us Boost Timing Module MSD junkies, 10* advance with vacuum retard active/5 psi threshold/2* for each psi retard curve, adjustable or DWUR, mandatory AFR monitoring, larger intercooler, 1.0 boost max, 92 and above octane - and I think we've taken as much risk out of the additional timing equation as possible for street draggers. The only remaining piece that I want to see to fill in a blank spot is: What is the timing at 4000 rpm's with .8 to 1.0 bar of pressure applied to the BTM? If either of you haven't put your baby to bed yet this year, that little pice of info will help us sleep at night. Accept the risk with eyes wide open, enjoy the ride, or sit on the porch with the old dogs and watch the world go by. I'll buy you a cyber beer after work tonight. |
I got a good laugh from Cole's post...
Recently I gave a cute girl a ride in my car and I saw her looking down between the seats for a few seconds at the little red MSD knob I installed on the top of the autoheat box that says, "boost retard". can't imagine what she was thinking and decided it was best not to say anything. . . |
MY Twisted Brother,
I have a ROW 930/60 Engine Max HP is at 5500 RPM Max TQ is at 4000 RPM Your timing is going to be most critical at Max TQ or 4000 RPM through Max HP at 5500 RPM, (Time to shift), Timing needs to be 18*- 22* BTDC at that point. Now we can put the toys away for the winter and go rob banks or something. I've been following the Grandpa Bandit on TV and they haven't caught him yet. He looks like my other brother Earl, I could do that and buy more parts. J. Don't you be driving fast while some cute chick is playing with your Knob. Cole |
In regards to what your factory dizzy is doing. I have created a crude graph myself on my 911SC by running the engine at increments of 500rpm from idle on up to 6000rpm and recorded the timing with an adjustable strobe at each set point. I then constructed a graph in excel. this tells you what you got. I then correlated it against the timing charts from the factory manuals superimposing the mechanical advance curves on the vacuum retard curves to see how it compares. You could try the same thing if you have the factory timing curves for the turbo, where you would need to superimpose an additional timing curve for the boost retard. This is something i wanna try ot do in the future, and will try to post results. Hey the blood pressure cuff is a good idea for generating boost at various psi while runing the engine without load in the driveway! The question of what safe point to set final timing when advancing timing in search of more performance versus factory data is still subject to individuals interpretation. The factory spent lots of dyno time tuning the engine so I cannot say how far one could deviate from those specs off hand without tuning on a dyno and spending $$$ the same way. |
I have the thin black siemens 60's. I talked with a guy today that stated the injectors become "non-linear" under 1.50% duty cycle. Which matches what i've found.
My car does not have a cold start valve anymore, which i'm sure isn't helping matters. But I have been holding the throttle slightly open for a few seconds after cold start to help it stabalize. I may do an on-off valve for cold start, we'll see. This thread has become so huge that it is easy to get cunfused, I'm so glad to have control of timing fully. |
A generic starter motor button is a good way to manually trigger a cold start valve injector.
If you don't have one for a 3.2 manifod, maybe one from an older motronic or L- jetronic 6 cylinder BMW is the same or similar and will cost less. |
You don't need no stinking cold start valve with MegaSquirt II. Make sure the IAC is half way open during cranking. Set the ignition timing to 10 BTDC during start-up. Adjust the start-up injection quantity until the car will start, then die after about 2 seconds. Then increase the after-start enrichment until the car stays running. After that, adjust the afterstart decay so that the after start enrichment is all gone after about 2 minutes. The start-up injection quantity is just like the cold start valve. The after start enrichment is just like the warm-up regulator.
Is that 60 lbs/hour for the injectors? If so, that is only 7.6 gm/sec, which is not too big. Over 9 gm/sec is too big. What is the spray pattern. Hopefully not the pencil spray. That is not good for our engines. |
No offense but EFInjection stuff is just going to get lost here and be of little use to those that might benefit from it if it were in a thread on an EFI build.
The best. ;) |
Hey Fred !!!
Great to hear from you. Hope the new job and location are suiting you well. Weak minds must wallow in the same gutters because I got the Mtyvac and pressure simulator to do exactly what you have done. With the LM1 and all the feedback I'm going to be collecting I should be able to dial this thing in pretty well. I got the blood pressure cuff bulb and tire gage idea from a post some place. Wish I could remember so I could properly credit the guy. It's ingeniously simple and dirt cheap. I got the bulb for 4-5 bucks and the tire gage with reset for 10-12 bucks all off evilbay. All I have to do is put a T in the gage line and add the bulb. I converted my manuals to PDF and I can print pages and take them with me to the garage. Works out well. Keep me posted on your progress and Thanks for the heads up. Cole |
Yeah, back to the timing topics. Why are 930 engines presented here with such weak timing? Why are people taking out so much on such little boost? Seems to me that these motors are setup to take much more advance. Another thing that I noticed is the a lot of people are taking their boost reading from the back of the intercooler where the factory sensor is. So that 1 + bar is bogus. I have a boost switch on my intercooler set up for 1 bar but I take my boost reading from the manifold in front of the throttle body. 1bar in the intercooler is like .8 bar in the manifold. What this says: a lot of false information related to real boost/timing curves.
I thought most took there boost reading from the intake manifold after the throttle plate.
A 930 running 1 bar is about a 11.5/1 effective compression ratio or about the same as a 993 which has twin plugs. On top of that our intake air is preheated even with a decent inter-cooler. We do not have any compensation to pull back timing with changes in environmental conditions nor any knock sensing ability. Thus we should have some level of safety built in. A 993 only runs about -16 deg at TQ peak (where a motor is most sensitive to timing) which is about what we run on boost. The 993 also has the ability to bend the timing curve which we do not. Thus, it seems we are running about as much advance as we can get away with safely under varying conditions. http://forums.pelicanparts.com/uploa...1259900288.gif Stolen from 911chips.com |
Z,
Would be interested in what your non weak timing is. What advantage is there to more advance on a 930, and what does a real boost/ timing curve look like. THANKS !!!! Cole |
Hi Cole. I see a lot of 930's with their boost readings taken from the intercooler, thus all this 1bar+ running is not the case and everything is not factual related to real time pressure events in the cylinders - timing, too. When I got my car, I could easily swing the boost gauge past 1bar with marginal power results. I fooled around with the timing and actually got it running pretty strong with 26-27 with an old HPV1 twin pac. When I inspected the motor compartment, I switched the line to the manifold and the boost stabilized at .8bar yet I still kept the timing. Anything lower with timing and the motor turned sluggish. I've since rebuilt the motor with all the go-fast goodies along with modern ignition controls. The stock motor showed not a single sign of detonation. Anyhow, a lot of post here about timing and boost is misrepresented based on this pressure loss. I see aggressive timing reductions starting at .5 bar, like -2 per pound or 16 all the way up. Just seems weak to me, that's all. I start pulling closer to peak boost and leave the lower levels alone. The car blazes. I've also heard that the older crazy fast cars with single pots had no boost retard at all but I think some of this was covered here on this post but I don't recall it actually being verified.
zcoker- my mechanic told me (back when i had the stock dizzy) to just unplug the vacuum lines and run the dizzy locked at 25* BUT make sure to run good fuel. Told me the car would fly, and i believe him. Now I have full ignition control and will start to gradually ramp total timing up from my base of 16*in 2* increments on the dyno to see what effect it has on power. I see 200kpa at the intake manifold with a 1 bar spring in the gate. (my wastegate also gets it's signal from the intake manifold as apposed to the inlet side of the intercooler)
FYI
cont.
drmatera,
Yes, setting it up on the dyno is the only way to come to a proper conclusion. The apx. -16 that we believe the factory puts timing at on boost may be a little conservative of a lot depending on the build and ambient temp's. The best "educated guess" I could get was from Steve W of 911 chips and he thought we might be able to take up to somthing in the 18-20 deg range on boost. Remember his chips do pull timing back with higher ambients. Again, a weakness of CIS is the lack of safe gards and often less than ideal AFR's that may also call for a margin. Thus a well tuned 930 w effecent turbo and intercooler might preform well near -20 on boost if well maintained and somthing like a dirty injector dose not make for one cylinder to run lean. Quote:
see, now this is where it gets confusing
"""-25 setting is what Bruce Anderson recomends in his book for a modified 930. However he keeps the boost retard function""" that statement confuses itself. to save tons of confusion why can't somebody just say what the total advance at WOT (which i might add means full boost) is, period. The max timing you should see at WOT and 1 bar on a basically stock 930 is............... ? |
A bassically stock 930 should probably not be running 1 bar. I have seen what that can do.
-16 on boost is bassically what the stock setting comes to and has worked well for a lot running 1 bar. -15 at 1 bar would be in line with BA's recommendation once you boil it down. That is derived from the factory recommended -26 deg total advance with no load at or above 4000rpm with apx -9 to -10 deg of boost retard for a net of -16 or so. Anything more aggressive is a modification and one would be well served to be validated on a well maintained motor (balanced injector flow and proper AFR) with proper testing on a dyno. Just my opinion. Not sure if this is what you are asking. |
The unknown question is at which point in the boost curve will additional advance become dangerous. That's why you see us starting to retard away the additional timing we added starting at around .3 bar (5psi) so that all the extra timing is gone sometime before full boost is reached. That's why a stock distributor timing curve relative to boost levels would be nice to have, so we can set the MSD to drop off the timing to somewhat match the stock distributor curve. Make sense? |
