-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   EFI guys please stand up... (http://forums.pelicanparts.com/showthread.php?t=528099)
David 08-30-2010 04:43 AM
Here's the latest pic I have (it's not as pretty with wires and hoses everywhere :D):
http://forums.pelicanparts.com/uploa...1283168532.jpg
Here's how I laid out the M600 wiring although I don't have about 1/4 of the stuff actually wired like the wheel sensors and cockpit switches:
http://forums.pelicanparts.com/uploa...1283168619.jpg
gsmith660 08-30-2010 05:00 AM
Looks very nice. Did you make your own billet brackets?
Raceboy 08-30-2010 05:24 AM
The silicone insulated wires that I used don't crack with heat & cold cycles and I have the harness made from it in my turbocharged 924 for 4 years, no hardening of the wires, nothing. Withstands contact with exhaust without melting etc.
There is always numerous ways of doing things but 1200 for harness materials is clearly overkill for a hobby racecar. There is just no point in claiming the most expensive way is the only way. Question is: what is the goal? And follow the requirements to achieve it, be it with your wallet or your brain (or both).
David 08-30-2010 05:41 AM
Yes. I'm not a machinist (well maybe an amateur machinist), but I work in a machine shop so I have access to the machines.
http://forums.pelicanparts.com/uploa...1283172072.jpg
drb930 08-30-2010 06:11 AM
Originally Posted by David (Post 5532171)
If you're really good at wiring you could do it yourself. I'm above average at wiring, I built the harness myself, and I wish I paid Motec to build it.
I spent about $1200 in material to build the harness for my M600. I checked, double checked, and triple checked and I still made a couple of mistakes. I could have saved myself a lot of heart burn by shelling out the extra money for them to build it.
I put a bulk head connector at the fire wall to make pulling the engine easier. Even though I used very good DT gold plated connectors, I wonder if it doesn't add unnecessary risk for a bad connection.
I have a lot of aviation avionics installs, do you think that will qualify?
Thanks for the input,
Dave
David 08-30-2010 08:32 AM
Dave
You'll probably do much better than I did :D
My biggest issue was ground wire connections in the harness. I crimped them together using standard unisulated butt connectors and heat shrunk them. For some reason I got a few bad readings when checking the harness and had to open it back up and fiddle with the connections. I don't know what I would do different, but hopefully a good wiring guy would do better.
If I did it again I would use better heat shrink tubing. I used pretty good stuff, but I'd spring for Aero quality stuff next time. Especially since there are good Tee's and other shape shrink tubing from Aero suppliers.
I was glad I used good DTM connectors even though they're more expensive and require a $300 crimping tool, they are a much more positive connection than Weatherpack or others.
TimT 08-30-2010 03:22 PM
I use "expandable mesh sleeving" for the bulk of the harnesses I make, only using heat shrink at the terminus of each circuit...
Sleeving
And Weatherpac connectors.. mil spec connectors are cool.. and better than the Weatherpac if a customer wants mil spec thats what we build... If he want to get a harness that works just as well and costs much less than the mil spec... Weatherpac..
I can't find pics of the whole harness I built for my car, but here is the expandable sleeving, and the bulkhead connector
http://forums.pelicanparts.com/uploa...1283206898.jpg
http://forums.pelicanparts.com/uploa...1283206917.jpg
930gt-40r 08-30-2010 03:31 PM
Tim- you use Ballenger Motorsport?
TimT 08-30-2010 03:43 PM
We probably buy from the people that supply Ballenger ;)
Had not seen that site before
