Turbofrog
smurfbus's Avatar
Would this work for 'limp home' or valet mode
If the turbo goes it might still smoke too much if I don't reroute or block the oil line.
Just had some creative time at the garage : )
Old 01-30-2011, 12:09 PM
mark houghton's Avatar
Looks like a low compression version of a 911 engine now...sort of. Can't see why it wouldn't work. Just keep the extra parts in the glove compartment for those emergencies.
Man, you've got stuff re-positioned all over that motor....like the AAV, WUR, even the MSD sitting on the engine (might overheat in that position).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 01-30-2011, 02:51 PM
Turbofrog
smurfbus's Avatar
MSD has been there for many yrs in Arizona weather so I guess it can take it. The AAV is going out (early hand throttle) and the WUR I just placed there so it's more accessible when I install my custom IC to be used with a ductail or carrera lid. I think I need to get rid of the compressor for them to fit though at least the carrera plain lid interferes with the compressor
No need to keep extra parts at the glovebox as those pipes/hoses are from the custom kit. This would definately help with joyrides if I need to leave the car in a bodyshop or detailer that I don't trust.
Old 01-30-2011, 08:51 PM
If preventing joy rides is your main concern, then probably just as simple and maybe less time consuming would be to remove the WG and install the softest spring you can find (.3 bar maybe) or perhaps leave the spring out alltogether so the turbo can't build any boost. The joyrider would simply not be impressed.
I'm all for better accessibility of the WUR vs. it's stock location. And your MSD location....I guess it's a testament to a quality product, but I would think that eventually it may suffer a shorter lifespan....but maybe not, apparently.
Old 01-31-2011, 05:55 AM
Turbofrog
smurfbus's Avatar
So where have others installed it?
The experiment came from the idea of turbo failure somewhere far away from civilization.
Old 01-31-2011, 06:43 AM
The MSD? Left fender, basically where the stock CDI would reside (just forward of the rear fuse/relay panel). Some have installed it on the firewall.
Old 01-31-2011, 09:13 AM
beancounter
jwasbury's Avatar
For "valet mode" I'd look for a way to limit engine RPM.
I've got the electromotive ignition and if I were leaving the car in un-trusted hands, I can limit RPM to something very low and boring...like 1500
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-31-2011, 01:22 PM
Turbofrog
smurfbus's Avatar
That might be too low. Imagine if they took it for a spirited drive and try to WOT in a tight spot in a road with a lot of traffic.
Not sure if my MSD 6AL has those pill options (supposedly resistors) too. What size would I need for say 3000rpms?
Old 01-31-2011, 09:03 PM
