Boost Freak
Maxx1's Avatar
Unhappy Is the oil temp not getting to 180 degrees cause for concern ?
I heard that a 180 degree oil temperature is the magic number to burn out water vapor and prevent sludge from building up in the engine. The only problem is, in cooler weather it's hard to get the oil that hot especially on a short trip somewhere (less than an hour)
I'm running conventional oil, but would switching to synthetic oil eliminate the worry?
... (at the expense of possible leaking) ?
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 11-25-2011, 05:11 AM
Non User
infraredcalvin's Avatar
Your thermostat may be stuck open. Have you verified everything is in working order?
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 11-25-2011, 01:08 PM
Boost Freak
Maxx1's Avatar
No, it just takes a long time for the oil temp to reach 180... usually more than 45 minutes if the ambient temp outside is 50ish degrees or less. Many of my trips are around 20-30 minutes and the oil temp is right around 130. Where is the oil thermostat located?
Old 11-25-2011, 04:17 PM
floor it.. it'll go higher
Old 11-25-2011, 06:08 PM
Non User
Thermostat is just in front of the right rear wheel, it's in the housing that has the metal oil lines running from it under the rocker and to the front. Get the car warm enough and feel the metal pipes forward of the thermostat or in your frnt wheel well, if thermostat is open they'll be warm or hot to the touch, it's not supposed to open until 180 deg or so.
JFairman is right though, a few boost runs and it'll warm up fast...
Old 11-26-2011, 02:33 AM
Boost Freak
Maxx1's Avatar
Talking
Jairman is right though, a few boost runs and it'll warm up fast...
I'll bet it must be stuck open! I'll have to check it out! Thanks.
Yeah, I know running it hard will heat things up faster
Old 11-26-2011, 05:30 AM
