more parts, its like christmas everyday around here
new nascar duct, i couldnt take the paper **** anymore with ripping and bending new starter ring gear new throw out bearing new pilot bearing new cv boots and clamps flapper box gaskets new tunnel bracket for shift rob (thanks for IMR Merlin) ![]() ![]() began cleaning my balls ![]()
Banned
How did your balls get so dirty in the first place?
Stay in budget!
I almost wet myself on that one. That's like the Spanish Inquistion! No one expects to stay within budget. ![]() Looks great however!! |
i think the budget thing is a long shot, i get it, BUT, i have alot of "stock" (old parts from past builds), that i have been storing for times like these
to sell off as need be, which i am sure will help, so far so good |
sand blasted heater boxes, and painted
![]() sand blasted axles, painted, and new boots on ![]() ![]() cv joints all cleaned and ready to be re assembled
Jim, you still need that CV?
Banned
I'll have to check the one that were on the car looked ok, but it's been a year since I looked at them.
small update, sorry, it has been to cold to spend long amounts of time in the garage, and i am still waiting on alot of parts to arrive before i get building...
new clutch disc new starter rear shock tower kit (coilovers coming) wevo joint )wevo shifter comes tomorrow ![]() took the stock shifter apart and painted the base gloss black (this might change to flat black, the Wevo will be silver, so not sure how the gloss will go with it) ![]() ![]() ![]() got my heating system apart and replaced that ****ty paper hose ![]() CV joints are back together, new flanges will be here friday, picking up my transmission on friday ![]() removed about three more wire harnesses -sun roof -warning buzzer -seat belt light -modified brake light harness to removed entire warning harness and retain brake lights -still one more harness to remove there is a ton of unused wiring in these cars. |
o yea, got the dog a new bed with some Cars sheets
Gotta take care of the dog, they usually stay in my life longer than women do!
nascar duct
where did you pick up the heater duct? Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Enjoying the progress... good job!
JIC, be sure the orientation of the CV assembly is correct, if not there is a 50/50 chance. |
looking good and watch out for that slippery slope
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
I really like what you did with the defrost and heater ducting, it gets rid of all the crap in the trunk. Will you have heat and defrost when you're finished?
I noticed you mentioned you can't find a CV flange. You may want to check into some of the off road part vendors. There are a ton of options for 930 CV parts in the off road world. |
I think he will have some heat and defrost but not alot and only what is available from the engine cooling fan.
Older BMW 7 series lobro CV joint boot flanges are the same size and will work too. The dune buggy guys like them better because they have looser internal tolerances than 911 CV's and tolerate the increased axle to CV angles better. EMPI makes low cost copies of lobro CV joints and CV boot flanges. You see them on ebay. |
