jetjox
Thanks Trond!
jetjox
jetjox
I'd like to share my info with those interested. I've been messing with efi 930's since 94. Most of my testing has been at the 1/4 mile.
jetjox
JRod Badass 911 Turbo - YouTube |
Crotchety Old Bastard
That's yours! I have that video saved in my archives. What a sound! Can you post pictures of the car it looks really nice from what I can see.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
R.I.P.
yes i have drooled over that video many times.. a cammed 930 is a sweet sound
jetjox
JRod |
jrod, thanks for letting me be a part of this thread. the car as stated a few replies back is a 78 930 with a modified ls7 motor with KEP clutch components and stock four speed gearing with lsd transaxle. the car weighs slightly less than 2400 pounds and has 17 inch wheels. seems the ls7 power is more linear and keeps developing power up close to 7000 rpm. the dyno chart is engine dyno..thanks for any comments... maxwedge528
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp |
jetjox
it is just a street driven car. at least at this time. primarily interested in how you would access the car in the quarter mile especially with the stock gearing. do you go through the top end in your first, second, and third gears? etc...
jetjox
JRod |
R.I.P.
jrod, these 4 speeds are a ***** to launch but I have cut a 1.77 60' with it. The clutch was screaming for mercy but it lived. KEP PP and kevlar disc
jetjox
Yea, it's just so hard on them, it might hold up for a few passes but not for too long
The sintered iron material holds up pretty well though. 1.77 is very good with that 4 speed What was your et and mph on that run?JRod |
R.I.P.
11.79 @ 119. I have since trapped 122 but havent been launching to aggressively as that ET was 12.25
jetjox
That's a good pass, are you running more boost to pick up the mph?
R.I.P.
I'm running a different turbo than the 119mph pass and right around the same boost 18-19psi
jetjox
Well, the change worked out for you then. What turbo were you using before? I see you use the MS2 system. I've never used or tuned with one, they seem to work well?
R.I.P.
yeah, i went from a K27 to my bullseye S262 originally. I ended up sending the S262 back for an upgrade and had a little T3/T4 60mm turbo laying around so we stuck it on the car. spool up was instant but back pressure was thru the roof. The 11.7 was with the little 60mm, i since put the S262 back on and have only been back to the track once since then. I need to get back out before the hot weather shows back up.
R.I.P.
oh, love the MS2. It's a great system
jetjox
Good info on those turbo's. Checking the back pressure is very helpful, i need to do more of that myself.
