Chain fence eating turbo
I trapped @ 124 @ 2750 lbs
Old 01-25-2012, 06:55 AM
jetjox
Send a message via AIM to jetjox
What's your setup Tippy?
Old 01-25-2012, 08:08 AM
Carrera 3.2 w/3.4 Max Moritz/Mahle P&C's 7.5:1 CR running 1-bar from a T60-1 Turbonetics.
55lb injectors and custom chip from Protomotive. Heads, intake, cams, etc., stock C3.2.
Stock G-50 with KEP stg II PP with Kevlar disk.
Tial 48mm(?) WG w/1.625 primaries, 2.25 secondaries IIRC headers.
No boost until 5500 RPM in 1st gear, reason for slow ET's of 12.40.
Old 01-25-2012, 08:24 AM
wjfk32's Avatar
Do have numbers for 60-130mph..,,Nice setup-
Walt
Old 01-25-2012, 09:51 AM
R.I.P.
drmatera's Avatar
Yes back pressure is often overlooked. The little T3 wheel was giving me 40psi (and climbing) exhaust pressure at 12psi of boost. All was fine till 4500 rpm then the pressure skyrocketed. It showed on the dyno as well. It made 345rwhp no matter how much boost or timing we threw at it. The S262 has a T3 inlet but a wheel sized similar to a Q trim T4. I have not had time to do back pressure testing but at 17psi she made 450rwhp. Stock 3.3 engine with Carrera intake
Old 01-25-2012, 12:22 PM
jetjox
Walt
No, but perhaps I should test that?
Old 01-25-2012, 05:34 PM
jetjox
That's the kind of real world testing that must be done on all these different turbo combos. So much can be learned but no one talks about it or shares info about results. The Supra guys share a lot of that info and is perhaps one of the reasons they have made such huge performance gains over the past 10 years. Oh well...
Old 01-25-2012, 06:01 PM
jetjox
Update, finally trying E85 fuel. I will be tuning it on the dyno prob tomorrow, any advice from experienced e85 tuners out there. I added 35% across the map and it's running real well. Actually the fuel is Ignite fuel ethanol based. I know it's going to make some good numbers.
Old 02-21-2012, 09:22 PM
vas930's Avatar
Good luck.
Look forward to seeing the numbers.
79 Silver 930 SOLD
Old 02-21-2012, 09:36 PM
R.I.P.
drmatera's Avatar
what you'll find is big torque increases in the 2500-4500rpm range under WOT by adding some timing in a little at a time. I go in 2* increments. Peak timing can be increased as well but I don't think you'll need to be much over 26* at full boost.
Can't want to see the numbers.. My bet is an increase of atleast 60hp
Old 02-22-2012, 04:27 PM
jetjox
Well, I rolled it tonight and quickly found that 1000CC injectors are not going to cut it. I installed a 1 bar spring and it's really making 1.2 bar. The duty cycle went over 90% past 6100 rpm, af was too lean so i shut it down. Didn't bother optimizing the low end numbers since new injectors are in the calling. The fuel I'm using is 114 Ignite and might contain more than 85% ethanol? Judging by what I saw the numbers are going to be big...
JRod
Old 02-23-2012, 05:54 PM
Hey Joe what is the scoop on the fuel lab fuel pumps? I have twin 044 pumps on the car. Instead of adding a third I might go for their 1800hp pump to have cushion on ethanol
Old 02-29-2012, 09:49 PM
What kind of starter are you running? I did not know there were lightweight versions...
Old 03-06-2012, 08:28 AM
R.I.P.
drmatera's Avatar
jetjox...... you holding out on us? I gotta know how the power compared
Old 03-06-2012, 04:23 PM
jetjox
I should have it on the dyno within the next couple of days? I've had to modify the fuel rails and should be ready tomorrow? I'll tune it on the street first and then get it on the dyno for power pulls.
JRod
Old 03-12-2012, 07:25 PM
jetjox
Got the new injectors in today and pressure tested the system, checked good. Now I'm doing the new program and tomorrow will begin the tuning. Hopefully I'll get it on the dyno later in the afternoon, after I work the drivibilty tune and cold starts etc etc... Keep you guys posted.
JRod
Old 03-13-2012, 09:37 PM
You're maxxing out 1000cc injectors? Wow!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-14-2012, 11:29 AM
R.I.P.
drmatera's Avatar
on E85 . That 1000cc is down to a 700cc on the corn juice
Old 03-14-2012, 04:40 PM
Ah, just saw 90% duty and 1000cc and thought, wow!
Old 03-14-2012, 07:19 PM
jetjox
Well, I finally got around to tuning the big injectors using Ignite fuel. I was having problems with miss fireing. It ran pretty good under light loads but when I put some boost on it, well I had the missing. I checked everything and all look ok, so I pulled all the plugs. The plugs did not look too good, having a fair amount of run time on them. I changed them out and took the car out for some street tuning and after working on the fuel map the car runs great. No misses at all and feels very strong, hopefully I can get on the dyno tomorrow and compare my numbers?
Old 04-08-2012, 09:42 AM
