Where did you get the oil catch can?
Many, many...many moons ago I did an unconventional K&N adaptation whereby I hacked off the end of the stock airbox, brazed on a plate/fitting to hold a huge filter, which opened up the area beneath for access to the WUR and AAR while still retaining all the stock hose connections to the "breadbox". Kinda stupid approach but the thought was to keep the normal tunneled air flow into the air flow metering arm. Thinking very seriously this time around of trashing the breadbox and going with this more conventional approach.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Banned
Swapping to a K&N intake on a 930 mainly improves airflow and engine sound, less restriction than the stock box and a nice turbo whoosh. The most common setup is the K&N RU-2970 filter with a custom or aftermarket bracket.
Uhhh...2970 is a dual inlet filter according to K&N. Perhaps they've changed their numbering system. Other options are 5163 and 5109. I do like the oblong shape provided it isn't too tall.
Regards Ned
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body |
Went to the K&N several years ago to rid myself off the airbox pain and make adjustments easier. Had a catch can for a while but it was always empty so I sold it and changed to the small air filter at the oil tank vent.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
I have never had anything in my catch tank, and that is all track driving. If I do find oil in there, it will be a bad day.
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Can you guys share part numbers that worked for you?
Stre mentioned ru-2970, but that seems wrong: https://www.knfilters.com/ru-2970-universal-clamp-on-air-filter?srsltid=AfmBOooR4UgE016NJn3Ptc5VQNAGKF7_CBT zmFa-Lf7HOGamrI9iMZYR There is this "custom aftermarket bracket" mentioned. Fabspeed sells this: https://www.fabspeed.com/fabspeed-porsche-911-turbo-930-air-intake-system-1976-1989/ but that kit seems a bit overpriced. (unless someone can convince me it's worth the price)
88 BMW 325 86 911 Turbo |
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. Last edited by mark houghton; 04-21-2025 at 07:36 PM.. |
Quick Learner
This is what I used on my 1988 930.
https://a.co/d/hys2S1d https://a.co/d/bmZRWL1 https://a.co/d/5xqtX6B Not sure of any power increase, but you can't mistake the sound of that turbo winding up and dumping now... And its just so much cleaner under the lid. Very happy with the finished product for under $100. ![]() ![]()
Crotchety Old Bastard
The K&N RU-5163 cone filter frees up a lot of space but like everything K&N it adds no power. We've done dyno runs on engines producing less than 400whp using the OE mailbox, K&N and no filter at all and see zero significant difference in output. I'll post a picture of our carbon fiber filter housing once ready for production. It will retain all of the connections so no auxiliary filter will be needed.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Wow. Thanks! That looks soo much cleaner! And super cheap to try. I'll give it a shot.
Done...plus a couple cheap Chinese air filters (not shown) for the two breather hoses that used to connect to the OEM breadbox. Probably not really necessary but would catch any oil mist. Haven't run the car yet, just need to slap the IC back on.
Where are you kids running the vent hose off the WUR when ditching the mailbox? Don't really like the thought if the diaphram blows out and pukes fuel all over the engine.
I am not running one.
Hmmm. Alan
Well shoot Alan, you're no help...at least not today!
Nope. No help at all.
My car came with the K&N filter, and I had never even seen a 930 when I purchsed it over the internet. So I never knew anything different. Now I am thinking I should fit a tube to at least dump to waste. I did have a fuel leak once - I could smell the fuel in the engine bay after finishing a race. It was a cracked line at the FD head - where it exits to join the WUR. It had cracked and was spewing fuel in to the engine bay. That was a close one. That line had a mod fitted to it - Google says it was a Mercedes fuel enrichment device. The vibration of that unit hanging off the FD/WUR line finally caused the line to crack at the union. Could have ended badly. Alan
So where is this hose going?
Hey there,
Great question! Swapping out the stock airbox on the 930 for a K&N intake is pretty popular, especially among those looking to free up a bit of extra performance and clean up the engine bay. The major advantages typically include: Improved airflow – The K&N system allows for better breathing compared to the restrictive factory airbox, which can translate to a bit more throttle response and power (though gains vary). Reusable filter – The K&N filters are washable and reusable, which saves money over time compared to regularly replacing paper filters. Simpler look and more space – The aftermarket setup usually opens up the engine compartment a bit, making it easier to work around. As for the specific system, many go with the K&N RU-3510 or a similar cone filter combined with a custom or aftermarket pipe. Some even fab up their own brackets to get the fit just right. If you're still running the stock CIS (Continuous Injection System), be sure to get something that mates up cleanly without messing with airflow metering. Just keep in mind – more airflow can mean more intake noise, and some purists prefer the original airbox for its OEM feel and sound dampening. Hope that helps! Sincerely, Chris Hennessey Founder of 52nd Street Auto Wash Grand Rapids and Surrounding Areas, Michigan |
Nope. CIS intake on a 930 is 5 inches in diameter. RU-3510 is 2.125". So that pretty much leaves #5163 as the only option that I'm aware of.
