Lowering Engine
Ive looked in the forums but cant find the way to just LOWER the engine, i dont want to take it out just lower it enough to remove the airbox and possible cis for servicing,
In the porsche projects book its about an 8 hour job..with everything including the clutch disconnected. Is there an easy quick way???? Any links or howto's pls post !! THX
Bad LT
Ex Porsche Cup car with some boost and stuff. Last edited by Uncle; 11-02-2013 at 02:43 AM.. |
Thx Fingers crossed
Metal Guru
Why would you attempt to perform a partial engine drop to remove the air cleaner and CIS? That's like performing brain surgery to cure a headache. All that stuff comes out easily with the engine in the car.
Even if you end up dropping the engine and transaxle out to do something like replace the sound pad, it's pretty simple to do; it's not the pain in the butt like dropping the powertrain on a 964 Turbo is (power steering and hydraulic clutch to deal with).
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Time taken to drop engine = under 60 seconds Also needed to check that all the lines are secure, had to check as i undid 60 percent of vacuum lines that i could reach with no tools, fingers only, so it was important Secondly need to clean, replace anything wrong Thirdly cos i F#%$ing wanted to!
Champagne on Beer Budget
Today is free advise day...You asked for advise and throw this out because you don't like one of the responses?
I'm sure there will be even more folks lined up to answer your next question.
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
Sometimes comments are made without reading the original question as in this case..
Ive never lowered an engine before, Uncle pointed out it was only two bolts. Then a comment was made about it being difficult and likened it to brain surgery? Id hate to change a tire then,Will i need a 4 year Degree for that? Secondly My reply ended with a smiley... A smiley indicates the writers view/emotion at time of writing.. Ill explain This means COOL, meaning Im Cool Hope you now understand the context. <------( Thats a grin cos im finding your post even funnier.
TGIF CHEERS!
Metal Guru
Funny how I find myself posting less and less over here due to incivility and the constant d**k measuring contests.
First thing I thought when I read the post was why the f**k would you want to lower the engine to take off the air box.
![]() Obviously I wasn't the only one. You got an appropriate response given the question asked. There are allot of incredibly knowledgeable and talented people (fewer all the time) here that take the time to answer our questions. Seems to me that's the case here. That's your thanks? Not so IMHOA little humility goes along way
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
I get the impression that Robbbyg is a very young man - the latest and greatest generation - and while attending his classes in "cockiness", missed his classes in "good manners".
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Preferred pronoun:Maestro
What he ^ said.
When in doubt, use overwhelming force. |
Bad LT
Ahhh I just worked out who you are.. I've edited my first post to suit. You might recognise the quote..
Ex Porsche Cup car with some boost and stuff. |
Lowering the engine give alot more room to work and takes abouts 60 seconds as Robby found out. I guess just loosen the rear engine mounts will do it.
I did NOT think Robby was rude or didn`t show enough respect to the elders here. He was clearly joking and having a good mood is 10 times better than having this "kiss my hand like the pope" act before someone answers. Everyone has asked "stupid" or easy questions that others disagree with, help out or just don`t bother. That is what this forum is for!!!! I see this all the time and really gets to me. Smile! Answer the best you can! Open a beer!!!! |
Chain fence eating turbo
The post quoted by Uncle is sacrilege of English! Talk about kettle calling the pot black.
