Preferred pronoun:Maestro
Boost Signal for MSD
I’ve locked my distributor in order to be able to take advantage of the 6530’s boost and ignition retard features. Part of that process was, of course, disconnecting the vacuum advance to the distributor. My question is this; will the vacuum line that formerly went to the distributor provide an adequate/appropriate signal for the MAP sensor?
When in doubt, use overwhelming force. |
I would say that the connection has too small ID to be able to used as connection to MAP sensor.
But it might work
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Chain fence eating turbo
I would think you are fine. The nipple on my MegaSquirt is uber tiny and my car is 100% MAP.
Used the port on top without issue on my SDS EFI for MAP. Port at the bottom is used for BOV
Roland 930 Turbo '81 Too many modifications to list |
Smart quod bastardus
It does not need alot of flow it just needs to get a pressure signal so small diameter hose should be fine. Make sure you are using a 3bar MAP sensor for the MSD because you need vacuum as well as boost signal and anything over 1 bar boost requires a 3 bar sensor. Please post pictures of your MSD reetard curves when you get them programmed so we can see what you are running and comment how it works in the engine. thanks, Fredmeister
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
