Turbo Hooligan
if you are tracking go lower, just raise the pick up points.
![]() ![]() Esthetically I like the flares at the tops of the tires.I would lower your nose down and see how you like it.
D-Zug ![]() Last edited by pkracer21j; 09-03-2014 at 07:50 AM.. |
![]() I'm going adjustable and here are some choices. Are any here that much better or easier to adjust settings? ![]() Or this
63 356 So Called Outlaw 76 930 |
Thank you
I vote for #3....note: if ordering, speak with Clint first...this will insure he has the part in stock....
Rey....77 930 "the Mistress" |
Option 3 is coil-over only, right?
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Yes you are correct...if your doing euro height...I think the factory plates should suffice.
Non User
He's got a 76, so the spring plates are the "non adjustable" types... I don't have any first hand exp., but I've seen a lot of sway away and weltmeister versions on cars and floating around. I think they're basically the same to adjust, prob made by the same Chinese mfg too...
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
Talked to Clint and he actually did suggest the sway away. Their high end is coil over. So I'll have 29 torsion bars adjustable ride height on an ancient car. What not to like?
The only down side to the aftermarket plates is you will lose about 1/2" space in the wheel well, which would affect fitting fatter tires.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
Looks perfect to me.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
Turbofrog
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
![]() Parts came in yesterday. Could have the beast back on the road next week
OK, here is my take on stance, but it is just my personal taste, way too low for most out there.
![]() ![]() Now for the bottom line...What exactly do you want out of your car? If it is just to get it low, then adjustable rear spring plates and twisting down the front adjusters will work. However, it will ride like s#@t, it will handle like s#@t, trust me I've been right where you are at. I too started with the simple approach, like I noted above, bad end results. I then went a little further, with various different parts-n-pieces, still no joy. What I wanted was a low car, that rode well, handled very well, and was not too harsh to live with. When you drop a 930 very far, you lose too much suspension travel, bump compliance and steering balance, not to mention the fact that your suspension is no longer working in the proper range or with the proper geometry. There is only 1 way to really do it right...... Here is what I ended up with for an overall great package with virtually no compromises. Rebel Racing front control arm bushings. Rebel Racing rear spring plate bushings. 22mm front & rear adj. Tarett anti-sway bars. Wevo weld on rear anti-sway bar mounts. Strut tower brace. 23mm front torsion bars. 31mm rear torsion bars. Front spindles raised 40mm by ERP. ERP bump steer kit with welded braces. Von front strut inserts, custom valved for my torsion bars. Von shocks rear, shortened overall length, custom valved for my torsion bars. Fikse 18" x 11" rear rims with 295-35 BFG KDW 2's. Fikse 17" x 8.5" front rims with 1/4" additional negative offset with 255-40 BFG KDW 2's. Corner balanced & with aggressive street alignment. Tire life, about 10K on the rears & 18-20k on the fronts. No it was not cheap, but I could have saved about $750 by not trying the first two trial-n-error approaches, and just simply have done it right the first time. My .02 worth, take it or leave it. Mark Last edited by full quack; 09-19-2014 at 09:06 AM.. |
![]() Here is the stance it's had since 95. It doesn't eat tires and tracks straight and true. I don't want to go much lower so its an ongoing endeavor.
once I saw his car I had to go the same route, ERP and Rebel will help in all areas Kozmo
My opinion of course, but the latter factory style wheels do nothing for the earlier body style.
RGruppe #180 So many cars.. so little time!! |
anyone want to make me an offer? And to think I passed on many used sets of Ruf for 1,000. Or any # of Fuchs.
![]() From our host.
930T Owner
Looks great. The RSR look will be very nice for your car sir.
Chris.
Hams930T 2017 Turbo S |
Back from the alignment shop. All new suspension. Went with 30mm torsion bars in back which tightened it up a bit. Ready for some fall road trips.
