Chain fence eating turbo
Any of you guys have inlet temp numbers?
I've used 3 different turbos on my Carrera 3.4, and have seen inlet temps 10-15 degrees over ambient on 100+* days using a 3.5" thick core, full bay IC with 2.5" inlet/outlets.
The Turbonetics 60-1 (60mm) and Borg Warner S366 (66mm) both have ran similar temps, the Holset HX40 (58mm) ran the warmest, but spooled ~1000RPM sooner, possibly accounting for the additional heat.
Curious what you guys see using which turbo and IC.
I've ran 1.2 and now 1.4 bar.
Old 01-14-2015, 11:16 AM
GJF GJF is online now
Slantnose from HELL
GJF's Avatar
I usually see 5-6 over ambient all the way up to 2 bar never pushed it over that. It has been pretty rock solid keeping those charge temps since running the pair of 46's, the 60-1's and the new hybrids. 4 1/2" core (2) 2 1/2" inlets and 100mm outlet.
It changes from time to time.....
Old 01-14-2015, 11:45 AM
5-6 over for mine would normally be on 80* days.
Very nice for 2 bar!
Old 01-14-2015, 12:01 PM
Have you guys noticed any difference in throttle body air inlet temps when the sunroof is open or closed?
I ask because it's possible the air going over the roof and flowing down over the back window and into the intercooler is a relatively smooth flow pattern when the roof is closed.. and maybe it becomes disrupted with turbulance when the sunroof is open.
Does the intercoolerd air temperature raise a little when the sunroof is open?
Old 01-14-2015, 07:25 PM
I never logged with sunroof open, but that's interesting.
Old 01-14-2015, 07:27 PM
Das Schnell Ei's Avatar
are the temps at a cruise or is that the IAT at full boost?
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 01-15-2015, 05:21 AM
Slantnose from HELL
GJF's Avatar
IAT at WOT on full boost,
Old 01-15-2015, 05:32 AM
not bad at all ....... thats about the same efficiency as a good front mount intercooler
Old 01-15-2015, 05:56 AM
Non User
infraredcalvin's Avatar
I'm also interested in data supporting this. On my 3.0 (non intercooler) I see a rise in oil temps on 90 deg days If I have my sunroof open. Temps drop if I close it.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 01-15-2015, 06:52 AM
iat at wot on full boost,
+1
Old 01-15-2015, 07:42 AM
xbmwguy's Avatar
6-7 degrees above ambient with gt 4094 and 3 1/2 " full bay on 90 degree days. Much less on code days
Old 01-15-2015, 05:28 PM
How much boost?
Old 01-15-2015, 05:30 PM
copbait73's Avatar
Hi guys pressure drop is just as important. Do you have that to share also?
Old 01-15-2015, 06:10 PM
Stranger on the Internet
patkeefe's Avatar
Although my turbo SC is a bit different in configuration, I have two transmitters; one at the entry to the airbox, and one inside the airbox past the throttle plate. I also have no tail on the car, and run about 6 PSI boost. The ambient sensor pretty much measures ambient when the car is moving. Temp in the airbox is usually about 145F off boost. I don't recall it ever being over 200F even at the track. Intercooling is via water injection only, no air-to-air intercooler.
I don't log any of these data points, so I don't remember exactly, but I do recall reading that the actual temps in a 930 at the port inlets could be in excess of 300F without intercooling and 1 atmosphere boost.
Patrick E. Keefe
78 SC
Old 01-15-2015, 07:01 PM
xbmwguy's Avatar
I don't know why Fairman is asking this question as I told him a few weeks ag that I logged both temps pre intercooler and after intercooler with roof open and closed. 2-3 degree temp diff.getting old sucks Jim
Old 01-16-2015, 03:13 PM
16Volt's Avatar
My up-pipe temp was 110 at idle and 190 at full boost on the dyno.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 01-16-2015, 05:23 PM
Wow! What turbo, boost, and IC (or lack thereof)?
Old 01-16-2015, 05:29 PM
I remember you telling me that. I was just wondering if anyone else with intercooler air temp sensors had noticed any difference with the sunroof open or closed.
I don't have any way to measure that and it's interesting so I asked.
...and yeah getting old does suck.
Old 01-17-2015, 03:09 PM
16Volt's Avatar
Stock 3ldz, TiAl - 1bar spring, B&B intercooler. Keep in mind, this was a IR temp gun on the up-pipe, the intercooler wouldnt come into play. It was about 85F ambient that day and car was fully up to temp.
Old 01-17-2015, 03:18 PM
Oh, so not after IC cooling?
Old 01-17-2015, 03:59 PM
