Turbofrog
smurfbus's Avatar
Two spare 38mm injector blocks anyone?
While I was cleaning my disassembly parts bin I found out two of my injector blocks are badly warped. I would like to drive this summer with the good old CIS and for next year switch to EFI. I Zdont think I could get the running as a EFI already this summer!
So let me know if you have couple of straight 38mm ones available. I have modded alublocks but those a for EFI injectors so I cant use them at this moment.
I just checked my dry install and there is more than 3mm valve piston clearance so the rpms must have skyrocketed to get piston-valve contact and brake the cyl6 exh rocker last sping.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 04-28-2015, 07:54 AM
Turbofrog
smurfbus's Avatar
This is number 6 witch had closed exhaust valve for a while so it banged on the intake manifold
Old 04-28-2015, 08:01 AM
