moparrob's Avatar
Alternative choices for TB on 3.2 manifold
I am putting together a turbo motor which will use a 3.2 intake manifold and aftermarket EFI. My original inclination is to use a stock 3.2 throttle body.
I understand that several vendors sell TPS adapters which can be adapted to the stock 3.2 throttle body. However, I was wondering if anyone has had success with any other readily available throttle bodies.
Thanks in advance.
Rob
Old 05-31-2015, 05:52 PM
Chain fence eating turbo
You can put an early to mid-'90's TPS from any BMW except the 318i.
You'll need a 0.500" thick aluminum (or other material) spacer/adapter, or shorten the 3.2 TB shaft by same amount. But, you'll still need to account for the different TPS pattern over the WOT switch of the intake.
Not sure if any other TB's bolt right up aftermarket without modification, but '80's Mustang 302 TB's are pretty cheap and feature a 4-bolt pattern, square like the 3.2.
They're probably the cheapest out there.
Old 05-31-2015, 06:58 PM
moparrob's Avatar
"you'll still need to account for the different TPS pattern over the WOT switch of the intake."
Hmm, I'm not sure what that means...
Old 05-31-2015, 07:10 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Most aftermarket ECU's can use just about any type of TPS sensor. Mustang TB's are readily available from JEGS or Summit Racing from BBK to ACCUFAB. Even eBay. It will require welding up your original bolt holes and re drilling for the new bolt pattern. And then of course the whole linkage adaption. You could take your existing TB to a good machinist and have them open up the factory TB to 75mm and replace the throttle plate, if you want to keep it factory appearing. But then again you are doing a 3.2 manifold conversion so the factory appearance is really out the window.
It changes from time to time.....
Old 05-31-2015, 08:00 PM
If you shorten the shaft to put the TPS flat up against the TB like the WOT used to mate to it, you'll still have to modify the TPS or TB to account for the hole pattern difference.
Old 05-31-2015, 08:03 PM
I've always assumed that a 75mm throttle body was too big for a stock 3.3 liter.
GJF I know your engine moves much more air than a stock one but do you think a 75mm throttle body would still work with stock heads and EFI?
1987 GP White 930
1977 Ford Bronco
Old 06-03-2015, 10:36 AM
moparrob's Avatar
Oh, ok. Now I understand about the bolt pattern difference. Thank you.
Old 06-03-2015, 11:09 AM
Why you might as well make a 0.500" adapter. Modifying the TB or TPS would not be fun.
Old 06-03-2015, 11:18 AM
