How to install intake elbow?
Trying to replace my old oil soaked and leaking intake elbow. The new one is very stiff and after an hour of struggling I still can't get it on. Is there a trick to this (engine in)?
Old 06-02-2015, 07:23 AM
Radiator hose tool. You can get them at Harbor Freight tools or google them and ebay has a bunch of them like these...
2pc Universal Radiator Hose Pick Tool Hook Seal Remover Removal | eBay
Old 06-02-2015, 07:30 AM
Great advice. Went to Canadian Tire and bought one like the tool on the right. Looks like a dental pick. Just $10. With a long screwdriver providing a push from one side, the tool slipped the elbow on in a minute. If I had only known!!
Thanks !!!!!
Old 06-02-2015, 08:56 AM
T77911S's Avatar
put a little oil on the inside of both ends.
i slide the elbow under the fuel lines towards the front of the car then slide it on the pipe to the turbo. then onto the AFM.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-02-2015, 09:55 AM
Motor oil will eventually dissolve the rubber that hose is made of after a while. It's fine oil mist from the crankcase breather and oil seperator being fed back into the stock air cleaner thats ruined his over time.
Vaseline or silicone divers grease works well to lubricate rubber hoses like that without rotting them.
Old 06-02-2015, 10:31 AM
Boiling water and soaking rubber parts in them briefly can also aid in these sort of things.
Glad the radiator pick worked for you
Ken
1986 930 2016 R1200RS
Old 06-02-2015, 02:05 PM
Used a little amourall. Slick but harmless
Old 06-02-2015, 03:47 PM
Turbofrog
smurfbus's Avatar
I would say soap water. It does not make the friction area slippery after it drys out.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 06-02-2015, 08:59 PM
