totle's Avatar
Lack of boost
Hi,
My car has lately less boost. I thought it has come and go between 0.8 and 1.0, but not driven the car that active. NOw I have prepared for a DE event, so tested out the car today WOT.
Boost table is set up for 1 bar.
0,7 wastegate spring. Tial wastegate. Now it boost on 0.8-0.9 bar.
My guess is air leakage somewhere, probably wastegate membran.
Any suggestion?
Could it also be boost solenoide?
Will try to increase boots table and see if it I get more boost.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 07-03-2015, 03:24 PM
If you can blow through the bottom pressure line on the wastegate either the diaphram is shot and leaking or the valve guide is worn out. It's difficult or it may be impossible to get parts for the original wastegates so replacing it with a 46mm Tial is the next option.
Around 9 years ago I found an original diaphram for the factory wastegate on the classifieds for around $35. I'm glad I have it in case I ever need it.
I also have a new Chinese Tial copy I never installed and it looks like it's really well made. Especially for only $79. Tial springs fit it too. I put a green Tial spring in it. It even came with a really nicely made chrome plated wastegate tailpipe. I sold the pipe for $50 around 7 years ago.
FWIW, it looks like the website I got it from is still active...
46mm WG Performance Racing Products for International Sales from SSAutochrome Inc.
Old 07-03-2015, 06:17 PM
If your boost control solenoid is plumbed so it vents to atmosphere with no power to it (failsafe mode), disconnect power to it and check boost pressure with just the wastegate spring. If the boost pressure is somewhere in the range you are seeing, then the solenoid valve, wiring(power, fuse) or computer output could be the issue.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 07-04-2015, 07:14 AM
Is very busy
TheRedSlantnose's Avatar
Is your intake connected to the throttle via a rubber boot/90-degree elbow? Assuming it is, it may have loosened up somewhere and could be causing a small air leak.
I had that problem at the beginning of the year, only my case was more major; the 90-degree elbow came loose and sprung a leak at the top of the throttle body, causing my car to lose over half of its boost, dropping all the way down to 0.4 bar.
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 07-04-2015, 03:35 PM
T77911S's Avatar
the elbow usually gets soft and colllapses.
if the diaphragm leaks wont the WG stay closed?
valve guide wore out on my factory WG. i am questioning my tial but everyine says they leak some.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-04-2015, 05:59 PM
Non User
infraredcalvin's Avatar
Which results in an overboost condition...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 07-05-2015, 10:25 AM
totle's Avatar
Yes of course, you are right. Failed diaphragm would cause in over boost. My bad
When solenoide has no power, it boost 0,7 as the spring stiffness in the WG
Trond R.
1986 944 Turbo
Old 07-06-2015, 01:31 AM
totle's Avatar
Found out why boost was lacking.
My guess was that there was an air leak somewhere.
After inspecting around for broken/cracked hoses, I noticed one screw on the turbo compressor housing was missing. The threads was broken, so decided to remove the housing insert a helocoil.
When removed I also noticed that the silicone seal gasket had blown away.
No wonder there was less boost :-)
Trond R.
1986 944 Turbo
Old 07-07-2015, 10:44 PM
totle's Avatar
Or maybe the Garrett GT35r does not have sealing gasket?
Trond R.
1986 944 Turbo
Old 07-08-2015, 03:33 PM
I don't know about the GT35R but I do know the Garret GSX 61 which is built on the Garret TO4Z has no backplate seal like the 3K K27 turbos have.
So... I'm going to guess the GT35R has no big silicone o-ring seal around the backplate like the K27 turbos have.
The current day Garret turbo backplate and compressor cover interface is machined to a much finer degree of precision than the old K27 turbos. No o-ring seal is needed there.
Old 07-08-2015, 03:58 PM
MikeD930's Avatar
Gaskets are not used in turbine/compressor housings on Garrets. Hopefully one missing screw contributed to loss of pressure. Are there any signs of contact between the compressor blades and housing? Also, suggest to check all intake plumbing (condition of hoses and clamps) for leaks.
MikeD '87 930
Old 07-08-2015, 04:00 PM
The GT3582R does in fact have an orange silcone o- ring seal at the compressor housing to backplate, or at least mine does. I screwed mine up adjusting the compressor housing angle when I first put it on the car. I have a new GTX3071R and it does not have a seal between the compressor housing and the backplate. I just used a thin coat of bearing grearing to help seal that area.
-Dennis
Old 07-08-2015, 06:33 PM
