Banned
Anybody install a G50/03 in a 965
Anybody install a G50/03 in a 965 ? what is needed o complete this job? I feel the G50/03 is better geared for a turbo 911.
Should bolt into your car..965 had G50/52 and they are very similar, same nose cone etc.. maybe output shafts different.
RGruppe #180 So many cars.. so little time!! |
Banned
They do look very similar but the G50/52 is a little longer, I believe by installing the shorter G50/03 it would move the engine forward about an inch, which would cause the engine tins not to line up to the engine bay and also the intercooler may not line up with tins on the turbo tail ? whats your thoughts?
How many inches are we talking here? Is the difference in the case, the tail housing or the bellhousing? Maybe re-fab the mount if it doesn't throw-off the geometry of the half-shafts.. and of course see what this does to the linkage..
Of course you could pony-up and re-gear the G50/52.
Banned
I was thinking the same thing...has anyone one done this before?
Interested in that 50-52 transmission if u do swap out.
75 930, 76 930, 83 SC EFI turbo |
Banned
It will work no issues, but you should think twice on doing this, your 52 is a much stronger gearbox than the 03, bigger pinion ring, stronger main shaft and case, etc., on the other side of the equation you can sell the 52 for a pretty penny (10 to 12$k easy) , which I wont do if I were on your shoes.
![]() Last edited by Ultrafast993; 07-30-2016 at 05:27 AM.. |
gearhead
Just put the G50/03 3rd, 4th and 5th in your gearbox. You don't want to give up the large turbo ring and pinion or LSD.
Finding used takeout gears from the NA gearboxes isn't usually difficult. I've got a 4th here I'd sell for $400. Compared to my new gears at $1200 that's nothing.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Crotchety Old Bastard
You're spending a lot of $$$ putting the OEM drivetrain back in this car, I would stick to that as the value is not insignificant.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Banned
Well... I have no choice, my shop said that they would not complete the install if didn't install the correct trans G50/52, So I found one with 10k miles on it, for tons of money...Can you say.... slippery slop...
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
gearhead
And Ultima GTR... And Singer... Though really only the last one is usually willing to spend real money. 50/50s and 50/52 have been $10k gearboxs for most of the last decade. Getting one for less is the exception not the rule. Last one I did, 8 years ago, I bought for $12k and sold for $18,500 once it was gone through.
big boost connection
this will fit without Trouble.
Same shafts, same size. The 50/52 is much stronger. Regards |
