Banned
Anybody install a G50/03 in a 965
Anybody install a G50/03 in a 965 ? what is needed o complete this job? I feel the G50/03 is better geared for a turbo 911.
Old 07-29-2016, 06:13 PM
onboost's Avatar
Should bolt into your car..965 had G50/52 and they are very similar, same nose cone etc.. maybe output shafts different.
RGruppe #180
Old 07-29-2016, 07:09 PM
Banned
They do look very similar but the G50/52 is a little longer, I believe by installing the shorter G50/03 it would move the engine forward about an inch, which would cause the engine tins not to line up to the engine bay and also the intercooler may not line up with tins on the turbo tail ? whats your thoughts?
Old 07-29-2016, 07:32 PM
onboost's Avatar
How many inches are we talking here? Is the difference in the case, the tail housing or the bellhousing? Maybe re-fab the mount if it doesn't throw-off the geometry of the half-shafts.. and of course see what this does to the linkage..
Of course you could pony-up and re-gear the G50/52.
RGruppe #180
Old 07-29-2016, 07:57 PM
Banned
I was thinking the same thing...has anyone one done this before?
Old 07-29-2016, 08:49 PM
lite75's Avatar
Interested in that 50-52 transmission if u do swap out.
75 930, 76 930, 83 SC EFI turbo
Old 07-29-2016, 09:21 PM
Banned
It will work no issues, but you should think twice on doing this, your 52 is a much stronger gearbox than the 03, bigger pinion ring, stronger main shaft and case, etc., on the other side of the equation you can sell the 52 for a pretty penny (10 to 12$k easy) , which I wont do if I were on your shoes.
Old 07-30-2016, 05:12 AM
gearhead
Just put the G50/03 3rd, 4th and 5th in your gearbox. You don't want to give up the large turbo ring and pinion or LSD.
Finding used takeout gears from the NA gearboxes isn't usually difficult. I've got a 4th here I'd sell for $400. Compared to my new gears at $1200 that's nothing.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-30-2016, 05:30 AM
Crotchety Old Bastard
RarlyL8's Avatar
You're spending a lot of $$$ putting the OEM drivetrain back in this car, I would stick to that as the value is not insignificant.
Old 07-30-2016, 08:07 AM
Banned
Well... I have no choice, my shop said that they would not complete the install if didn't install the correct trans G50/52, So I found one with 10k miles on it, for tons of money...Can you say.... slippery slop...
Old 08-02-2016, 07:58 AM
Metal Guru
911nut's Avatar
You are probably competing with a bunch of GT40 replica owners for that tranny
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 08-02-2016, 10:28 AM
gearhead
And FF GTM Mulsanne...
And Ultima GTR...
And Singer...
Though really only the last one is usually willing to spend real money. 50/50s and 50/52 have been $10k gearboxs for most of the last decade. Getting one for less is the exception not the rule. Last one I did, 8 years ago, I bought for $12k and sold for $18,500 once it was gone through.
1974 914 Bumble Bee
2009 Outback XT
Old 08-02-2016, 01:27 PM
big boost connection
myfisch's Avatar
this will fit without Trouble.
Same shafts, same size.
The 50/52 is much stronger.
Regards
Old 08-05-2016, 01:50 AM
