my '81 just dies when idling
hey guys
I have this very nice dream car a 81 turbo
trying to figure out why the car just dies when idling
HERE IS THE LONG VERSION OF THE STORY.
ALSO I'M NOT A MECHANIC BY TRADE
I bought it 4 months ago and fixing all the little things before unveiling it.
I did bring it to a Reputable Porsche Mechanic for it ppi and first full service
valve adjustment
fluids and all filters
plugs, cap & rotor
belts
brakes
etc.
he delivered the car back to me .and it sat for 3 weeks
tried taking it for a ride let it warm up and it backfired and stalled many time within a few blocks.
i made a u turn and parked it.
he picked car up
put fuel gauges on to monitor
then cleaned and adjusted the warm up regulator
replaced boost relay
replaced rear fuel pump
replaced fuel relay
car seem to run good and fast on test drive. he was driving
note: oil level gauge jumps
tach jumps when in boost
get the car back car sat for another 2 weeks
the car started right up
a puff of smoke ..cleared up in a few seconds
pulled car out of garage
car idled nicely for about 3 minuets the stalled like:
someone pulled the cord out of the wall
mechanic stopped by to checked it out
it was not a fuel issue (pumps stay running)
also
we do hear the high pitch sound(ignition box?) after the car stalls
I want to thank you all in advance for your input
I am tiring to learn as i go
and get this beauty back on the road with everything working as it should.
Old 10-01-2016, 08:48 AM
update
so it is not a fuel problem.
the mechanic put in a in line spark ignition tester.
it allowed us to view the spark thru the see thru glass.
with engine running for about 12 to 15 minutes it died.
we observed that the spark was the cause.
he plugged in a different cdi box and the same thing happened.
as the car got warmer it died quicker.
put testing light to see the out put of the box and it proved well.
the finger now points to the coil.
we will get another coil and continue the test....
Old 10-04-2016, 01:18 PM
Jeff NJ's Avatar
I hope the parts that the mechanic replaced without cause are going back to him and your money refunded. Reputable or not, replacing parts and hoping it fixes it is not a good sign. Especially when it turns out he replaced a bunch of expensive fuel system parts for an ignition problem.
Why cant he test the coil if he thinks its the coil?
Is it original? They are pretty reliable. The replacement ones available now apparently suck, so if you have a replacement coil, it may be the issue.
1988 930 Venetian Blue
Old 10-04-2016, 01:59 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
In your first post you mention "tach jumps" - often, a jumping tach needle is an indication of system voltage spikes due to a bad voltage regulator, so use a multimeter to measure charging voltage. High voltage spikes (anything above 14.5) can cause many of the running issues you describe.
Old 10-04-2016, 02:05 PM
the coil is original. do you recommend any particular brand .
the rear fuel pump was making noise so I thought it would be wise to swap it out.
Old 10-04-2016, 04:27 PM
ok i will check it out.
do you see any concern that the battery the previous owner put in this year was just a new but generic small sized battery. or should the car have a long type like originally equipped. porsche must have used them for a reason.
Old 10-04-2016, 04:30 PM
Small batteries work just fine, and in fact, put less strain on the alternator (less work to keep a low storage battery charged) - I've been using a 15 pound Odyssey 680 for many years without issue, as have countless other 911 owners.
The only reason I can think of that Porsche put that huge battery in (the original weighs about 65 lbs) is to try to lesson the car's poor weight distribution (a different version of the led weights in the front bumpers like found on very early 911s).
Old 10-04-2016, 04:36 PM
Jeff NJ's Avatar
Sounds to me like he is guessing that it's the coil. Have him test it or find a test one to swap out without buying a new one. If he cant or wont, find another mechanic. I don't have a replacement coil to recommend. I have just read here numerous times about new silver colored Bosch coils failing immediately.
The pump should be tested to see the amperage draw and flow rate to determine if it's failing. A noisy pump isn't necessarily bad.
Try Ronnies suggestion first, then test the parts instead of having the mechanic replacing parts until he stumbles into the issue while on your dime.
Old 10-04-2016, 04:46 PM
Alan L's Avatar
There was a recent posting where weird things happened to a 930. Turned out the boost gauge wire and Over boost switch wired were swapped. They are close together behind the intercooler (LHS). The wire to the o/boost sw is white and the sw is in the back of the IC - assuming all stock. The effects would be a bit like the bad voltage regulator - screwy voltage to your fuel pump relay and WUR.
You should be able to peer over the back and check.
And there is a rule on this forum. You need to post a pic of the beast, we never get tired of looking at them.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 10-04-2016, 04:53 PM
Ha ha, Alan, that was Jeff with the wires switcharoo!
Old 10-04-2016, 04:57 PM
Jeff NJ's Avatar
See? I speak from experience!
Old 10-04-2016, 05:03 PM
Alan L's Avatar
Well then .., anything is possible.
I nailed it then - but only in 20/20 hindsight. Now he got some other problem..
Just odd with the tach jumping when hits boost. I'm struggling to see where the connection would be. Like you say, the tach bounce is almost always a voltage spike.
Alan
Old 10-04-2016, 05:15 PM
Truff!
Originally Posted by Alan L View Post
I nailed it then - . . .
Old 10-04-2016, 05:17 PM
mark houghton's Avatar
Anyone can swap out parts....it takes a true mechanic to diagnose each part individually, which would require intimate knowledge. Tell your wrench dude you want back all the parts he removed, since you have paid dearly for new replacements. What he took off may very well still be good, so hang on to them as spares for future "just in case" use.
Jeff's suggestion is right on regarding the coil:
"find a test one to swap out without buying a new one. If he cant or wont, find another mechanic".
Unfortunately not all mechanics are equal. Some know Porsches, some don't, and some just rely on their customer's deep pockets.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-04-2016, 05:21 PM
Alan L's Avatar
Sorry - wasn't paying attention to who was posting what.
But to the OP, are you saying, to be clear, there is no spark when the engine dies?
And this takes place quicker when the engine is warm?
Alan
Old 10-04-2016, 05:36 PM
T77911S's Avatar
I am interested in the this spark tester that he used.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-05-2016, 04:04 AM
T77911S's Avatar
oh, your problem. the coil can heat up and cause it to stop running, I would look into the mixture and fuel pressures.
that seems pretty fast for a coil to heat up and quit.
RACE CAR:: sold
Old 10-05-2016, 04:08 AM
klefroid's Avatar
Well I had the same with a beetle few years ago. My money goes to the coil... Because the car dies without driving it so no movements in electrics. Check the green wire that goes to the distributor (small chance but easy to check)
Old 10-06-2016, 07:53 AM
UPDATE:
We tried a brand new Bosch coil car started right up and smooth
ran for 6 minutes and then died.
Old 10-13-2016, 08:31 AM
Alan
correct.
start car
runs smooth
let warm up
after several minutes (6min this time) you will hear 1 miss
about 30 seconds to a minute later 1 more miss
then a few seconds later it cuts off.
you will hear the high pitch noise from cdi box
Old 10-13-2016, 08:37 AM
