Bell intercooler p/n
Talked to bell about a full bay intercooler to carrera manifold , to my surprise they don't have a standard design, would anyone that has had one made by bell be willing to share a pn or job number from them,so they can look it up for reference.
Old 11-15-2016, 02:19 AM
TurboKraft's Avatar
Hi, if you're looking for a complete bolt-on package with inlet & outlet charge piping, bolt-on mounts to the intake manifold, all sensor ports, etc, contact us. That's what we make.
If you want just an intercooler with a generic inlet & outlet tank and a few flat strap tabs welded on, then Bell will do that for you.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-15-2016, 10:06 AM
xbmwguy's Avatar
Chris is spot on. If you want to do some fab work and come up with good anchoring points then gerhardt is your guy. I have had two of his and they work well. But for plug and play, all guesswork taken out Chris is the guy. I am using his now and won't look back.
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 11-15-2016, 04:00 PM
TurboKraft's Avatar
FYI -- Gerhardt is leaving or is gone, change of management and/or ownership. Not the same as it was.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-15-2016, 04:07 PM
ChaosRogue's Avatar
Chris, from that pic, it looks like the A/C compressor is still in there. How did you move the plumbing, etc. so it all works together? If I could find a solution like that, then I might be tempted to investigate a bit further.
Thanks.
1985 Guards Red 911 Turbo
1993 Midnight Blue 968 DE Mobile
Old 11-19-2016, 09:32 PM
930T Owner
Hams930T's Avatar
Thanks.
You'd have to reconfigure your car to run condensers in the rear fenders.
Griffith's can assist you in setting up your car for it. Pretty simple to do.
- Chris.
Hams930T
2017 Turbo S
Old 11-20-2016, 12:24 PM
ChaosRogue's Avatar
- Chris.
Makes sense. I have to redo all of my A/C anyway, so as long as it works, it's good enough for me. Thanks for the info!
Old 11-20-2016, 07:12 PM
Keep in mind that condensers in the rear wheel wells are smaller and don't get the same volume of airflow that you get from the one on the top of the engine, with the engine fan sucking air through it. Might want to ask Brian at Griff how much you lose from removing the decklid condenser.
I'd be interested in the answer, as I am going with two condensers in the wheel wells and keeping the half bay IC and decklid condenser.
Compromises, trade-offs and choices...
Old 11-21-2016, 07:56 AM
TurboKraft's Avatar
Actually, we've fit the condenser from the rear wing into the left rear fender well, added a fan on top. No problems, more effective than it was in the wing, colder vent temps.
Want really cold air? Lose the 2.5gal washer bottle under the LF headlight and install another A/C condenser + fan there. Ice cold in Phoenix in August, vent temps <34F.
And that's with R134a, not R12.
Most of these cars need new A/C hoses just from age.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-21-2016, 08:50 AM
