Idle and cruise Ve is pretty much there. The lean spots I was experiencing are gone.
I have been struggling a little with boost maps. Transitioning into boost from cruise. Just started on boost maps last night. Slowly leaning out the Ve map a load level at a time. My boost map bins are still pretty rich, I am getting a bog into boost. Data log shows it rich. Hoping to get some more tuning in this weekend. When running the VE Analyze what cell change do you set it to? Easy, Normal, Hard, or Very Hard |
I just got the latency injector offset table for my injectors. Injectors offset is .92ms. What is best way to dial in the voltage offset for the injectors?
Should I Calibrate the Battery Voltage, between MS3 Pro and Injectors? What is the correct way to do this? |
Plan on adding fan activation relay for oil cooler this weekend.
How's the tuning going John? Did you get on a dyno yet? Philip
Hey Phillip
Have not been to dyno yet. I have car dialled in very nicely. Autotune and Megalogviewer make the tuning process very easy. Idles quality is excellent. If you are thinking about doing Ms3 Pro, I would highly recommend it. Lot's of support on the Megasquirt Forums. Just want to give a big shout out to Dennis930 on Ms3 forums. He helped me immensely. I still have a couple of things to do. Still have to add EBC module, and add relay for oil cooler. Hoping to get to dyno in a couple of weeks. I will keep you informed. Regards John |
Jphn, if you think the MS forums are great, you should join the Facebook pages MegaSquirt Owners....... or MegaSquirt Addicts.
Hey Tippy
Yes, I am on both. Very quick response. Regards John |
John,
Glad to hear you got her dialed in. Now, I need to get busy with determining engine states for a 1.4.1 to 1.5.1 beta xx firmware update. |
Hey Phillip
I believe you would gain a lot from your particular setup. The thing that impressed me the most was how smooth the idle is compared to the SDS system. Gas mileage is great as well. John |
I have been holding off as well. Have you come across any good threads on engine states? Thanks again for all your help. Regards John |
I haven't got my setup running any better than it was with CIS+AIC1+digital distributor but then again it ran about perfectly before maybe even smoother. My only goal was to get more fuel for WOT and e85. So far fuel only for me but full sequential fuel and ignition by next summer.
Setting up and finding proper startup settings was painfull and the tunerstudio calculations very way too high so could not tell whats wrong. Same with cold start settings. It took time to get those decent. I did switch to ms3 ignition maps (with tach out to MSD) for better resolution and it helped with off idle. IMO the WUR cold start circuit is really good and simple setup with hand throttle. |
I contacted vendor that I bought the injectors from, and they provided me with the specs. I was able to dial in VE map using Autotune, Car pulls great, no hesitation. Still need to play with AE. |
I was able to dial in my VE table with TS autotune except for the upper RPM, high load (boost) areas, which have to be done with multiple datalogs unless you do it on a dyno. I did not have good luck with autotune for WUE, I think these engine like being a little rich for this. But TS autotune is based on the AFR table that is present, so if your AFR table is not what it should be then the results may not be as good. And as John mentioned, your injector dead time needs to be dialed in.
Smurf is running E85 which could be more difficult to setup due to the cooling effect of the alcohol. I have no experience with it, perhaps someone who has experience can help him out. |
I have my id1000 settings from ID, both deadtime and small pulse. It drives just fine but start ups are so and so. I go back and forth every other time. Same with veal and autotune but now I only use hard setting. First and second fight third and fourth. IMO CIS with AIC was much more stable but that was with high octane gas and wmi. I also installed a cherry hall for the cam but havent got time to dial it in or test it as my daily does not start anymore so I need to fix it (I think it might have other bank cam wheel jump one notch , maybe adjuster gave up) and use pcar as commuter which is not so nice in this state and traffic. Also the temps are getting colder so wue is on most of the 15 mile run. Semi hot start was very lean but I dont want to let wue go longer than 70 C. How hot do you guys run wue?
WUE is done by about 160F for me.
If your car isn't running, it's simply not tuned right. CIS cannot compare to EFI. |
Just saying my CIS was perfect with the add ons I had. Rough fueling maps and timing maps and the help of wur for cold starts. And I bet some other guy woulf tell tha t my car runs really good as it is now but I want modern drivability good.
EFI has the POTENTIAL to be 1000x better than CIS, but requires proper tuning and setup. It can be very time consuming to achieve modern day driveability. |
I do have a head temp sensor jammed between fins behind cyl4 heater tin. I think e85 is just slower to heat the engine.
I know its going to get better step by step but speed density is just OKish for engine management. I hope I can get gear dependant maps somehow later on. Or boost/gear like apexi avcr has from speed and revs. |
| All times are GMT -8. The time now is 05:44 AM. |
