MS3 Pro Conversion
Just wondered how many are using MS3 Pro? What features attracted you to MS3 Pro? Thinking of changing my current SDS EFI system. The SDS system is great for full out race applications, but lacks the refinement for smooth idle and cruise.
My goal would be to go full sequential for both fuel and ignition. I was planning on utilizing Honda COPs. I also want to incorporate electronic boost control. I was also thinking of upgrading the injectors to 80 lbs. High Z Injectors. Horsepower goals to the wheels 475 hp. I plan on fully documenting my conversion, in hopes that it will help someone else in the future. Any thoughts would be appreciated. Regards John |
If I were to do it again, I'd hands down do Pro. My understanding is, is the input circuitry is far less susceptible to noise than previous gens and the support is second to none.
I'm going Pro this winter. Just routed the VR line separately but likely the first start will be fueling only for easier troubleshooting. I'm installing the ecu and relay/ground_bars/fuseholder under the passenger seat for easier access (just pop the front side_bolts and tilt)
Pro is nicely documented and packed so it makes installing easier. The wires are printed for what they are and I bought the long harness so less connections hopefully. Grounds are the most important thing and I will use a thick gauge wire from starter bolt to common ground bolt/bar under the pass seat. Sensors ground to a named PRO wire. One relay AND separate_12V for PRO and fuel pumps relayed separately with switches on dash. http://forums.pelicanparts.com/uploa...1479963770.jpg |
John, I look forward to reading your write up on the conversion, I plan to do the same but probably not this winter, unfortunately. :(
I am running a microsquirt V3, which is basically the same as MS2, and have been very happy with it. It has quite a few features, but the biggest limiting factor is its spark outputs, and it will only do batch fuel injection with a 6 cylinder, and wasted spark. I even run knock detection, and Flex fuel, and am in the process of doing boost control also. I have had an issue with a hesitation around 2800RPM, and i think it may be ground related, but have not had a chance to diagnose it.
I would love to step up to the MS3 Pro, that way i could run coil on plug, sequential fuel injection. |
There is one unclear thing in the manual and its the grounding. Some paragraphs say block is best and one says battery negative is best and block ok?
Ground to the battery
Ground to the battery Ground to the battery Ground to the battery Ground to the battery Ground to the battery |
Why do they write this on their manual on chapter 4 wiring:
The ms3pro is great. It makes it so easy to wire and set up. My car started up first try after the conversion. Mine is grounded to the block and has been working great.
BTW, if anybody is thinking about buying one let me know as I have an account with them and can get you a better price. Ive sold a few on here already. |
This guy has a serious resume, even consulting with OEM's. He's questioned MegaSquirt heavily to change the ground documentation. |
Smurfbus, I like your location for the Ms3 Pro Unit, think I will do the same. I currently have the SDS unit mounted to rear seat foot board.
Has anyone used a bulkhead connector like the one shown on the diyautotune site? https://www.diyautotune.com/product/weather-pack-22-position-bulkhead-connector-kit/ I was wondering if the VR Pickup wire would work with this type of connector? Does the VR wire need to be wired directly to MS3 Unit? Is it a shielded wire? Same question for the cam pickup wire? Another question, what seems to be most popular sequential ignition setup, COP or LS Coil Near Plug? If COP what coils are being used? I will have lot's of questions going forward, just want to thank you guys in advance. BTW Happy Thanksgiving! Regards John |
LS2 truck coils (CNP) are the most cracking, but "xbmwguy" does fine with COP.
To me, it's finding: 1. Coils that have actual documentation regarding dwell times - very important!!!!!!!!!!!!!!!! 2. Fit the 911 head decent |
One more item.
I have a killer deal going on a SDS EFI system. System is for Twin Plug Setup. Includes EM5 Unit c/w Datalog function. Programmer, 6 DIS coils, 12 wire Clewitt set, Rich/Lean Tuning knob, Crank Sensor, Pulley backing plate c/w reference magnets, complete wiring harness, and manual. System is very easy to tune. Does not include the crank pulley, just the backing plate with the magnets. I could throw in pulley for extra cost. I can also provide 55 lb Hi Z injectors for extra cost. Simple Digital System EM-5 SDS EM-5: data http://forums.pelicanparts.com/uploa...1480035564.jpg http://forums.pelicanparts.com/uploa...1480035606.jpg If interested please shoot me a PM. |
Pro has a shielded two wire lead for VR sensor and it its best practise to be wired separately to avoid Starting problems. From my ecu position the wire reached just behind the passenger rearlight housing where I had my VR sensor wire (a cutted connector from my spare audi harness). So I routed the VR line under the rear lid latch to make sure it was far away from any ignition/pump/injector wires. I used chrink tube and alu wire shield over the wires near turbo/exhaust. I drilled a hole in the corner of the passenger back (level with trunk sideline) seat so there were no extra bends in the line to make it reach.
I will use that seat cradle for all the ecu related stuff and relay/ground/12V bars |
Thanks Smurfbus.
What coils are most popular with MS3 Pro? Found lots of Honda COPs at local Upull
$11.00 each, comes complete with connector. |
MS3 Pro has been ordered from Dos531, great price, Thanks Derek.
What is a good cam sensor to use for full sequential?
I strongly recommend the hamlin 55505 series. It can be ordered with the internal bias resistor which is needed for the cam input for ms3pro
| All times are GMT -8. The time now is 09:36 PM. |
