Sealing 3.2L Cylinders with 3.0 Heads
Hi Folks,
In one of Wayne's tech articles - he mentions the 3.2 cylinder is interchangeable with 3.0L cylinders, but offers the caviate that the 3.0 requires a gasket between cylinder and head and the 3.2 doesn't. The 3.2 cylinder has a slight slope, the 3.0 flat with a groove for gasket. Then suggests this difference is over-comable but goes no further. In addition, I'm struggling to find the differences in the mating surface of the heads also - are both flat neutral, or does the 3.2 head have an inverse slope? I've done a lot of digging here, maybe my search terms are wrong, But I would be hugely appreciative if folks could direct me on best practice to mate these parts with proper seal. Warm Regards Tom. |
The heads are basically interchangeable
Torque value changes from 25#ft to 15#ft+90 degrees sweep, The head intakes are different heights so the reason for the double gaskets and insulator. Bruce |
Thank you Bruce for the quick reply. Hugely appreciated!
Some clarifying questions if I may Quote:
I'd be curious to know the theory behind the change in approach to Torque approach - can you enlighten me please? Quote:
It reads like an extra consideration I should factor in - but gaskets for where (cam housing?) and insulators I'm not sure what that is. I re-read what I originally wrote and figured it could be read two ways - for clarity: I have a 911 SC 3.0L 1978 - just in case my starting point may have been confusing. So its a basic 3.0 build with 3.2 cylinders sandwiched between the 3.0 case and 3.0 heads. If I were to add that I'll either (a) use a stock Mahle 3.0 Piston or (b) go with something like a JE Piston - does that help color the job at hand? Does it make any difference to your reply? Warm Regards tom. |
Double gaskets and insulator sandwiched between the intake manifold and the head on the 3.2L.
You don’t have to make any changes. The cylinders are compatible with your heads. Just no CE ring on the 3.2 cylinders. No sealant. It’s a good idea to have your heads resurfaced to ensure a good seal.
-Andy
72 Carrera RS replica, Spec 911 racer |
This thread should answer your question on using 3.2 cylinders in a 3.0 engine.
3.2 cylinders vs 3.0 sc cylinders? |
Great thread. One detail missing for me however - the torque.
Would I be correct in saying - for completeness - the permutations and torque values areas follows: 3.0 Case <-> 3.2 Cylinder <-> no gasket <-> 3.0 Heads = 25#ft (my config) 3.2 Case <-> 3.0 Cylinder <-> yes gasket <-> 3.2 Heads = 15#ft+90 degrees sweep |
Try not, Do or Do not
Porsche struggled with a way to make Dilavar head studs work. They failed miserably and yet, continued to try.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Check what Flat6pac (Bruce) says on the higher torque Post 2 of 3.2 cylinders vs 3.0 sc cylinders?. Quote:
![]() 3.0 Case <-> 3.2 Cylinder <-> no gasket <-> 3.0 Heads Step 1: Torque to 15 Nm (11 ft. lbs) in sequence. Step 2: Torque nuts an additional 90 degrees. I agree with Henry Schmidt that the Porsche head studs have issues. I've used the Supertec Performance Cylinder Head Stud Kit on two different rebuilds and think they are the best solution. Edit After the initial posting, I realized I was guessing on which torque method had the higher final torque value. So to test it out, I used a M10 1.5 stud I torqued a nut to 11 ft lbs and then an additional 90 degrees using a deflector beam torque wrench. When 90 degrees was reached the beam torque wrench indicated about 85 ft lbs. Last edited by HaroldMHedge; 01-18-2021 at 07:09 PM.. Reason: Add Torque Test Info |
The penny dropped for me on this last email and my mis-reading was around the topic of 'higher torque' - I had originally assumed the 15Nm option to be less than the 25#ft option. That 90 deg sweep corrects that incorrect assumption I had. Thanks Everyone. Case closed - excuse the pun. Warm Regards Tom. |
