Solex cams
From my understanding, there are two cams. Are they the same grinds, lobes duration etc? Thinking of Waynes 2.0 to 2.2 Upgrade, or even a 2.0-2.4 stroke upgrade using the Solex cam and the 70.4 crank. Thoughts?
Old 12-03-2024, 05:25 PM
gearhead
I don’t remember the finer details, but I had this conversation with Steve Weiner a couple times and he always said to use Mod S over solex. While good in its day, the solex grind is outdated. That’s for the kind of build you’re talking about.
I have never heard of two different solex grinds.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-04-2024, 04:18 AM
Solex 248/236 242/230 .455"/.414" 97 4.2-4.6 mm
DC 30’s are modified solex cams 248/236 242/230 .455"/.414" 102 3.8 mm
I have Dc 30’s in my carb 3.0
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-04-2024, 05:49 AM
Emo993's Avatar
And I have them in my 2.2 E engine with S pistons. DC30 mod-solex, love them.
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 12-05-2024, 04:34 AM
solex cams
Huh! 5 degrees and .6mm lift make that noticeable a difference? I'd be curious to know what the (observable) differences are...power comes on more like an E vs S cam? I'm stroking a 2.2 to a 2.4 using 2.2 S P and Cs and Webers for my 914-6. So it will look like the stock 2.0 six (which is on the shelf), but have a few more hp.
Old 12-06-2024, 04:14 PM
For my 2.3, JB Racing recommended the Solex. I’ve been very pleased with the result. I’ve listed the engine details and engine dyno results in a post earlier this year.
dho
Old 12-07-2024, 08:07 AM
targa72e's Avatar
Here are some dyno Comparisions on some early engines I built.
https://forums.pelicanparts.com/porsche-911-technical-forum/1151593-dyno-summary-testing-early-2-4l-2-5l.html
john
Old 12-07-2024, 12:08 PM
Ran a 2.7 with euro MFI P&Cs, '66 solex cams, Webers, SSI in a '69 years ago. Great throttle response. You could lug it down to 1500 RPM in 2nd and stab it with no lag to speak of. Top end not as nasty as an S, but perfect for the street and getting out of a corner when the fat cam guys are waiting for the power to come up. Pretty much the same as an E cam.
206 637 4071
Old 12-07-2024, 07:30 PM
From my experience , Solex cams are great , a little more zip above 5000 than an E cam
but more low end than an S cam . I was disappointed with the mod S , definitely
more torque from 3000 to 5000 than an S , but they somewhat sign-off after 5500 ,
so it's really subjective and personal preference in the end . I'm talking about driving
for fun on the street , hilly roads with turns , not on a race course , and no 911 is good for stop light drags , although the mod S would probably be better than an S cam for stop light drags .
There are two Solex cam styles , center lube and regular .
Old 12-07-2024, 09:19 PM
Solex cams continued
One is definitely a right side...but the left has a weird number. Will the cam wizards chime in?
My cam book shows for 1965 Solex: Left 901 105 109 01 and Right 901 105 110 01
These cams are Left 901 105 103 01 and Right 901 105 110 OR
Can't get the pics to load.
Old 06-14-2025, 03:45 PM
Try not, Do or Do not
Henry Schmidt's Avatar
This thread speaks primarily to the effectiveness of the Solex cam and for a early clean sheet of paper, it was a great starting point.
That said, I have been building what we call a 2450 (70.4 x 86mm) the the formula was/is 9.5:1, 40mm Weber, 36mm intake ports, sport muffler, stock heater box exhaust and Mod "S" cams.
Of course all of our engines are built using modern techniques such as dry film lubricants and top quality bearing but there is no other magic. On the chassis dyno these
little engines make 180 RWHP and 6650 rpm. They tend to start pulling hard in the mid 2 thousands. Those kind of number will never be achieved with a stock "S" cam.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-15-2025, 08:11 AM
Banned
Depending on the year and intended use, there were differences like the Solex, E, and S grinds. For the 2.0 to 2.2 or 2.4 upgrade, the Solex cam is a great middle ground, good torque and driveability with solid top-end. Pairing it with the 70.4mm crank works well, especially if you’re using Weber carbs.
Old 06-21-2025, 02:45 AM
