Try not, Do or Do not
Henry Schmidt's Avatar
Here's the stand we built.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-10-2025, 08:37 AM
OsoMoore's Avatar
Henry I'm very confused about that engine with no cylinders. Testing fitment? Or new technology?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 12-10-2025, 02:13 PM
Just a mock-up. I believe that particular case is destined to be a table.
Henry Schmidt
Ph: 760-728-3062
Old 12-11-2025, 09:38 AM
[QUOTE=85RedCarrera;12576251]If you are talking about a danger involved with running these engines without a load on them...that would also be the case if you started and ran the engine in the car while parked.
How true !! Also fuel , oil and vacuum leaks , overall initial running , listening for strange noises , hopefully making you feel good of what you've done.. Absolutely not for breaking in the engine purposes ..
Old 12-18-2025, 12:02 PM
Still here
pmax's Avatar
Originally Posted by Tad240 View Post
Hi John,
Love that non-traditional ingenuity that gets the job done. Can you post a picture from the other side as well and include the mounting points?
Did targa72e post the pic you requested ?
Old 12-18-2025, 06:49 PM
targa72e's Avatar
Here is a picture from the other side. I am using a engine mount for a 914-6 conversion not the 911 cross bar. Oil tank in previous picture is also for a 914-6. I have added additional mounting holes to fit a 911 tank. Currently have a 3.0L mounted up using a 911 oil tank.
john
Old 12-19-2025, 11:22 AM
