who does fuel dist rebuilds?
hello, I have read the threads in how people are rebuilding the fuel dist. but have not found a company that does the rebuild. The one I have here has a stuck pinto valve and has been sitting in a shed for many years, will also need the wur to be done at the same time.
thanks. |
Fuel distributor rebuilds
A company called Cisflowtech.com
Reach out to boyt911sc here. Tony is a good guy.
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
PCA Member since 1988
+1 on Tony.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Brian at RarlyL8 has a relationship with Larry Fletcher’s CISFlowtech and might have some in stock fuel heads and WURs for a quick turnaround. Larry (if he’s still at it himself) is notoriously difficult to get ahold of and Brian Leask no longer modifies the WURs for adjustability. CIS is getting more niche by the year.
Ken 1986 930 2016 R1200RS |
Larry at CISFLowtech was our go to years ago. Is he still around?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
+1 for Tony!
Try not, Do or Do not
Fuel Injection Corp. (Robert)
2246 N. MacArthur drive Tracy, CA 95376 (800) 729-7118 Phone: (209) 830-6551 Fax Number: (209) 830-9715 kw21fic@aol.com I have used them for 20+ years without issue.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
We've always used Flowtech, and it always takes months.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
The 9 Store
+1 on Tony
All used parts sold as is. |
thank you
At the end of the day, it is not rocket science and rebuild kits are available for little money...
Cheers
For the brave ones, as Jeff Alton stated you can buy kits and attempt a rebuild yourself. Two companies I have purchased from are Salvox and CIS-Jetronic. Some are basic with the metal plate and O-rings, others have all the O-rings, shims, and copper washers to refit the fuel lines, even filters.
![]() Good thread on it. http://forums.pelicanparts.com/porsche-911-technical-forum/272657-cis-fuel-distributer-cleanout-w-pics.html The filters are very important to keep the system working correctly. there are quite a few in the system. I would recommend cleaning or replacing them even for those not re-building the fuel distributor due to the age of the systems. The fuel distributor outlet filters can be removed without taking apart the distributor just by removing the hollow bolt to the injector lines. There are many threads on cleaning the screens in the WUR's. https://youtu.be/0aD7bsj1ASg?si=UOeerN6Hs_qO_pVH While the ones in the injectors are not serviceable, the cold start valve ones can also be removed and cleaned. ![]()
Ed 1973.5 T |
Try Jerry Woods Enterprises (JWE), His "Master Rebuild" service is comprehensive.
