Another option maybe...?
A couple local builders like Permatex high tack especially for mag cases. Claim it stays more flexible than hardened 574, but was very messy. What kind of window of time does it provide before starting to harden, and just one or both case halves?
Old 05-22-2020, 11:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #661 (permalink)
After the next project
x98boardwell's Avatar
It seems that much has changed from the 911 engine rebuilding book that was done by wayne at Walt's place (Competition Engineering) in Lake Isabella.
In that book it recommends loctite 574 for most but Henry Schmitts shows different solvents (which I purchased and have) and I'm trying to see what to do in the morning....
I have 574 and then I have the others options for all surfaces.. some which include 574 and others.
Does anyone have the most updated list or has it not changed?
Thank you,
Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 06-13-2020, 08:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #662 (permalink)
gtc gtc is offline
abides.
gtc's Avatar
I'd suggest you start with this post, and scan forward through this thread.
FWIW, I have about 5 years on my motor now with these sealants, and the only leaks have been from the chain tensioner lines that I reused.
Originally Posted by CBRacerX View Post
NEW LIST (I've lost the ability to Edit Post #1 since it is from 2008...)
Outer Case Halves: Threebond 1104 (now 1184)
Bearing Saddle Surfaces: Loctite 574
#8 Bearing (balancer end) O-Ring: Threebond 1211 (now 1215)
Case Thru Bolts: Dow Corning 111 on Green Viton O-Rings
Flywheel Seal: DRY
Balancer Seal: DRY
Intermediate Shaft Cover to Case: ThreeBond 1211 (now 1215)
Oil Breather Cover to Case: ThreeBond 1211 (now 1215)
Cylinders to Case: Curil K-2 or ThreeBond 1211 (now 1215)
Cam Towers to Cylinder Heads: Threebond 1104 (now 1184)
Cam Chain Housings to Case: Threebond 1104 (now 1184)
Cam Chain Housings to Cam Towers: Threebond 1104 (now 1184)
Cam Chain Housing Cover to Cam Chain Housing: Threebond 1104 (now 1184)
Gaskets: Thin coat of Loctite 574
Thanks a lot folks, I really appreciate the feedback!
EDIT: Most Popular solutions for sealing added to each item above to include superseded items.
Graham
1984 Carrera Targa
Old 06-16-2020, 10:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #663 (permalink)
I have not seen it mentioned in the thread.
What, if anything, do we put on the metal gaskets with rubber bonded to the them, chain housings to case on 964 and 993 engines?
Thanks.
Old 06-19-2020, 03:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #664 (permalink)
#8 O ring
Originally Posted by gsxrken View Post
Thanks Henry. I hope we’re saying the same thing or I’m explaining it properly. A picture may be worth a thousand words here - I applied it to the o-ring, not the bearing.
Did Henry respond to this?
Old 06-20-2020, 08:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #665 (permalink)
Via phone call, yes. In a nutshell, The glueing of the case halves at the #8 and of the #8 perimeter itself is an optional insurance policy type of thing. I lubed the o-ring with the 1211 versus the bearing perimeter, so in my case I didn’t really glue the bearing, but he said I’ll be fine. I should know in a week or so when I install my engine.
I don’t want to misquote him here so I won’t elaborate. Perhaps he’ll chime in.
Ken
1986 930 2016 R1200RS
Old 06-20-2020, 10:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #666 (permalink)
Anyone else having doubts about 1104?
I'm thinking about switching back to using 574 for case halves and cam towers to heads.
The 1104 just seems to go off so quickly. I applied it to both case halves, but by the time I got to putting them together, (maybe 5 minutes) they were 'dry to touch'.. When clamped together, there was only a little squeeze out at certain areas, likely from where it was a little thicker. The sealant that did squeeze out, was soft and pliable for some time.. which leads me to think that my join 'should' be ok and leak free. But I will only find out after it's together and running..
Or should I just tear down the short block, clean it up, and use 574?
574 seems so user friendly in comparison...
Old 08-15-2020, 05:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #667 (permalink)
Jeff Alton's Avatar
1104 on the case halves (or its current iteration), your choice on the cam towers. We have had good success with both 1104 and 574 there. But never ever had a case leak with 1104 on the case.
To the previous poster that thinks Wayne's recommendations are gospel... Build a few engines, find what works for you. You MAY find some things in that book that you would never do.... As an example, we, like many pros in the industry, would never put RTV on a case bolt washer. Its a great book, we reference it often, but build a few motors and learn what it is right and what is.....
Read the thread. There is so many great recommendations. Pick your sealants, and go with it. There is not one solution, but pros (who have actually built many motors) have taken the time to give you their experiences.
www.turn3autosport.com
Old 08-15-2020, 09:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #668 (permalink)
Thanks.
Does anyone know about this?
Thanks.
Old 09-11-2020, 12:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #669 (permalink)
safe's Avatar
Thanks.
Nothing works fine!
Magnus
Old 09-11-2020, 12:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #670 (permalink)
Originally Posted by safe View Post
Nothing works fine!
Brilliant, thanks.
Old 09-12-2020, 02:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #671 (permalink)
Is ThreeBond 1104 aka 1184?
Old 11-05-2020, 09:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #672 (permalink)
gtc gtc is offline
abides.
gtc's Avatar
Yes, 1104 was replaced by 1184.
Graham
1984 Carrera Targa
Old 11-05-2020, 01:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #673 (permalink)
I was Rothsport’s engine and trans guy for 5 years, with another 40+ on each side. I’ll keep it simple, case 1/2’s and cam housings to heads: 574. Gaskets dry and Orings DC111. G
Old 11-09-2020, 10:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #674 (permalink)
thanks for posting!
I love 574, I think it's great stuff. That said, I really like 515 as well, it's the same consistency as 574 only it's purple, smells like grape jelly for some reason (not kidding) and has a higher tensile strength, and is more readily available not to mention cheaper.
No physical quantity completely explains its own existence
Old 11-09-2020, 11:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #675 (permalink)
DustoffDriver
Privateer383's Avatar
Having looked through the entire 34 pages of this thread, I am still a little unsure of what sealant, if any, is used on the "Crankshaft seal -front/pulley end", part no. 999 113 290 41 in the PET. Did I overlook it, or was it referred to by a different name? Some guidance, please.
Old 11-13-2020, 03:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #676 (permalink)
As stated above - dry. They have called it a balancer seal. In saying that, I’ve been a mechanic for 30 years and I always use a very thin smear of Toyota Seal Packing on both the rear main and front seals. It is a fantastic product. Probably like the Threebond/Yamabond but black.
Old 11-13-2020, 05:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #677 (permalink)
DustoffDriver
Much appreciated OSC911!
Old 11-14-2020, 07:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #678 (permalink)
Can anyone comment on the Yamabond or Hondabond equivalent to Threebond 1104/1184/1194?
Threebond is difficult to find here in Canada. Both Yamabond and Hondabond are readily available and used to seal case halves for motorcycle engine rebuilds.
Old 11-15-2020, 11:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #679 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
YamaBond and HondaBond are both made by ThreeBond. Check their data sheets for specifications.
Outer Case Halves: Threebond 1184 (apply to only one half)
Bearing Saddle Surfaces: Loctite 574 (only if you're confident of a quick assembly)
#8 Bearing (balancer end) O-Ring: Threebond 1211 in case saddle
Case Thru Bolts: Dow Corning 55 on Green Viton O-Rings
Flywheel Seal: DRY
Front pulley Seal: DRY
Intermediate Shaft Cover to Case: Thin coat 574 on gasket, Dow 55 on o-ring
Oil Breather Cover to Case: thin coat of 574
Cam Towers to Cylinder Heads: Threebond 1184
Cam Chain Housings to Case: thin coat 574
Cam Chain Housings to Cam Towers: Dow 55 on o-ring and thin coat 574 on gasket
Cam Chain Housing Cover to Cam Chain Housing: thin coat 574
Galley plugs and chain box pins: Loctite 9340 Hysol epoxy
We've been building engines using this technique for over twenty years.
That's nearly 200 911 air-cooled engines with stellar success.
Have others been successful with varying technique? Of course. We just offer our experience so first timers can have the best shot at success.
Pelican Parts offers the Supertec Case Sealant Kit with everything you need in one place.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-15-2020, 12:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #680 (permalink)
