OK guys, just ploughed my way thru most of this. I cant help but laugh when I look at the motor I'm working on at moment. It is a friends 2.7 that finally leaked so much oil I was embarassed for him and offered to strip down. About to reassemble this w/end. But the Japanese have got you all beat. This car came via Japan.
There they seem to use just one sealant - some marine grade silcone (white). You can dispense with the rest, just one large tube does all. Crankcase halves (was going to take pic, camera flat), nose bearing, crank seals , rocker bushes, all gasket surfaces. Apparently you just ladle it on with a spoon. I bought a 930 in via Japan, and same story - same white gunk everywhere. The 2.7 has about a pound of black RTV underneath to stop spot leaks, my 930 had red instead of black for spot leaks. So, if you want monochrome, go for white. If you like variety, red, white and black is available. Life can be simple. If you are Japanese. Regards Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
lol...
Does anyone here NOT use sealant on gasket surfaces. I rebuilt my SC from crank up 3-4 yrs ago. Followed Waynes recipie for sealing the case religiously.
But for all the gasket surfaces I used no sealant. Just made sure they were true and clean. My Dad was an engineer and taught me that an oil proof gasket should be enough, unless there is an issue. I know using the gunks is good insurance, and if was doing a shop job for a customer, I would not want it coming back for an oil leak. But am I the only one not using sealant on gasket surfaces? If you do have to pull anything apart again, it is a quick and easy job. If I had to pull it for a leak, if I could not identify a cause, I'm sure I would use sealant. My SC is still leak free. Regards Alan
Forced Induction Junkie
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I'm here to cause trouble
I don't use any on valve covers and chain covers... Didn't use any on the chain housing gaskets either. No leaks.... Proper torque helps a lot - especially resisting the urge to give it that one extra twist.....
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Alan
LOL! Ya true. I guess the point is, if your surfaces are clean and smooth, AND you assemble everything to spec, adding goop to your gaskets may complicate matters for you on disassembly.
I just this week popped the engine out (last time out was 2005) for some minor cleaning (lots of dirt, and a leaky pully seal and #8 bearing) and adjustments. ![]() It was pretty clean except for one of the tensioner lines, and the seal/#8 area, and all the gaskets released nicely. JB
Try not, Do or Do not
A quick note from the resident curmudgeon.
We would all like to believe that if we clean everything and make sure every surface is perfectly flat that the chances for oil leaks disappeared. It's a nice thought but in 1991 (the only time I could get accurate information, all factories hide these kinds of memos) the return from dyno test oil leak rate at the factory was 4%. That's 4% using all new parts. If 4% of the factory engines leak within the first 30 minutes using all new parts what are our chances of leaking using heat cycled parts. Our challenge is greater and requires a more aggressive plan of attack. Just my humble opinion.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry - all factory stats aside, I think the careful backyard Porsche mechanic may take a little more time making sure things are "right" as opposed to the factory engine assember who is under productivity pressures AND has a factory fridge nearby stocked with plenty of fine German bier!
JB
Sorry but that's just non sense. There is nothing more important than experience when it comes to engine assembly. We have built hundreds of engines and that experience leads to a better product. To think that a back yard mechanic can come close to the consistent quality of a factory engine assembler in naive in the extreme.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-04-2009 at 10:22 AM.. |
Henry - with all due respect, you missed my point entirely! But, we're getting off-track here...
JB
Off track for sure but let's remember that each engine moves though the assembly line with an assemblers number attached. Too many assembly errors lead to very long unpaid vacations.
This is not what I saw, but you see some of the assembly methods: http://www.youtube.com/watch?v=XdWTz_H0dUA So, I used sealant on my gaskets!
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 Last edited by CBRacerX; 07-04-2009 at 11:27 AM.. Reason: added link |
Jim,
I saw a thread recently where a leaky nose bearing was fixed with goop - by machining a tolerance fit piece, inserting goop in the gap and squeezing it somehow thru the cavity. That is about as much as I understood of it. But if required, could probably find thread. Regards Alan
Thanks Alan - I saw that - and bookmarked it!
http://forums.pelicanparts.com/showthread.php?t=481430 Jim
Greg
Ok, I'm the novice when it comes to these types of debates, but a simple question remains.
Any reason you won't use either 574 or Curil-T on all your gaskets? With all the time going into cleaning the case, the extra insurance makes sense to me. Nothing is worst then having a newly rebuilt engine run beautifully and drip on the garage floor, or on the exhaust. IMO, sealants on gaskets is the way to go.
Greg -79 930 Guards Red/Blk, "under construction" with an engine rebuild -65 Lincoln Continental Convertible - Green/Green/White top, "Constructed" |
1. 518 loses half of its strength at a lower temperature than 574, 90 vs 120 degree Celsius, but retained a bit higher strength at 150 degree C or higher 2. 574 cures faster than 518 as ambient temperature increases and may leave less time to torque the bolts 3. heat aging looks similar for both after 400 hours 4. 574 has higher lap shear strength but lower compressive shear and tensile strength So, your choice. But 518 will be easier to handle if you work in a hot environment. BTW, John Walker seems to be using the Dirko with good results.
'87 3.2 Targa |
New sealant question (I think):
What sealant do I use between the metal-to-metal joint of the left chain box cover and camshaft collar (through which the cam extends on a '68 with cam driven air injection pump)? I was going to use CurilT...
Bill G. '68 911 Ossi Blue coupe |
Ok, I really hate to ask this but is the first page updated with the latest common ideas on what to use? I guess I can read all 10 pages but would prefer not to. I know that there are several schools of thought but I just want to do it right the first time. Thanks and sorry for the lazy stupid question.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
68 911L |
