Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by tadd View Post
Henry:
Is there any more info to report on this super monster in its new home (track or street)?
I'd really be curious as to how it ended up on the dyno, where they actually run it at, and what kind of fuel it ended up using. It is uber wicked.
Personally, it is my absolute favorite of all your builds.
tadd
Thank you
The engine was sold to a race team in Florida and they haven't responded to my request for information. I'm believe that the car is not complete so the engine is on the back burner.
Originally Posted by daveytrackels View Post
I don't really understand..
So Davey, what can I do to help you understand?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-03-2010, 08:47 AM
tadd's Avatar
Henry:
Where did you chase up the '906' cooling tin? Is it more effective than the regular items?
Is that an instock item at Supertec? I need to order a set of head studs soon anyway.
Tadd
Old 04-08-2010, 05:33 PM
Henry:
Tadd
The cooling tin was designed to fit the 906 cylinders. We believe they promote better cooling. They a made by a US fabrication shop that makes some of our other products.
They come in two sizes. 2.0-2.7 and 3.0-3.5
Henry Schmidt
Ph: 760-728-3062
Old 04-08-2010, 07:48 PM
3 restos WIP = psycho
kenikh's Avatar
Well dammit Henry, how'd I miss these? I assume they'll fit Nickies?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-08-2010, 08:11 PM
al lkosmal's Avatar
Henry,
This is another work of art. I always look forward to your engine build threads. The best combo of engineering expertize and aesthetics I've seen. I always learn something while drooling over the pix.
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 04-09-2010, 08:25 AM
Originally Posted by al lkosmal View Post
Henry,
regards,
Al
Wow, this kind of praise, while perhaps not deserved, is greatly appreciated.
Henry Schmidt
Ph: 760-728-3062
Old 04-09-2010, 09:25 AM
a.k.a. G-man
Geronimo '74's Avatar
Great work Henry, you make us jealous!
Outstandinig!
Old 04-16-2010, 01:12 AM
120 HP/Liter is all I ask
I have used these 906 thingees of Henry's and they are nice bits that he came up with in those times between finding happiness and working on his rat rod.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 04-16-2010, 08:21 AM
tadd's Avatar
Henry:
Did you ever hear anything on this motor? I hurts me to be a pain in the arse to bother you over it since you tried before, but I'm just dying to find out how it worked out.
t
1967 912 with centerlocks… 10 years and still in pieces!
Old 09-19-2010, 05:52 PM
Constitutional Liberal
Turbo_pro's Avatar
Cool old thread
It always amazes me to see how innovative Porsche engine builders have been over the years.
As expected, Henry @ Supertec built an engine on the cutting edge and still old school.
Cool heads making high compression with flat top pistons.
GT3 Ty rods
Custom crank
906 cylinders with redesigned sealing surface.
906 cooling tin
and on, and on.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 11-20-2019, 06:18 AM
Exploring the possibility of building a 964/993 based, Extreme cylinder Head 104x66 engine with flat top pistons and peanut chambers.
We're hoping to save 70grams on the pistons making a 360gram possible.
GT3 Pankl rods, SuperCrank, Peanut chamber heads (Xheads) and super light CP pistons.
Looking for a 9000 rpm, 2 valve, 3.4SS, 911 engine.
Henry Schmidt
Ph: 760-728-3062
Old 11-28-2019, 10:25 AM
What Henry did.
That is very cool for your head design.Your thoughts and contributions are very important to us.Thank you for your efforts.Ciao Ciao Fred
Old 07-16-2022, 04:30 PM
Jeff Alton's Avatar
Lets explore this idea more. It seemed to die off with Covid....
Any progress?
Would be an extreme short stroke 3.4, super cool.
Cheers
www.turn3autosport.com
Old 07-17-2022, 09:59 PM
abit off center
cgarr's Avatar
We used to weld up the old VW heads much the same
______________________
Craig
G2Performance
Old 07-18-2022, 06:58 AM
Considering how much money we spend on Mezger engines I'm surprised heads with better chambers isn't a more common modification.
This is how Ducati do their twin plug air cooled two valve heads:
The cutout in the fins is for the cam drive toothed belt and the housing at the top holds the camshaft.
Old 07-18-2022, 11:57 PM
